bcintron95's S362-sxe B18C1 Dynamometer Results
#26
Re: bcintron95's S362-sxe B18C1 Dynamometer Results
Why is the S3xx SX-E series of turbo still such an unknown entity ? Finding non-diesel related dyno graphs, videos, data etc. is really hard. I'm genuinely wondering and not just trying to be a smart *** -the pricing is reasonable, the flow rates are competitive (on paper at least) and BW has a solid reputation for durable, well made turbos.
Has everyone just made the switch to PTE in this 62-68mm range and is ignoring the non-EFR Borg stuff ?
#27
#28
HP = (Torque x RPM) / 5252
Torque = (HP x 5252) / RPM
So, if we use the posted graph from the OP to illustrate my point, lets do some math. Since there is NO rpm on the "X" axis, but in fact vehicle/roller speed in mph... I am going to make some educated guesses... not to be specific in the values that are produced, but to simply illustrate the trend.
Let's assume the point at 98 mph is 8800 rpm and the point at 102 mph (the middle of the dip) is 9100 rpm. (I have used these values based on the relationship of the HP and Torque graphs at the point just before the dip being approximately 404 HP and 241 Torque).
So at 8800 rpm, the torque is about 240 ft/lbs and at 9100 rpm the torque drops about 40 ft/lbs down to about 200 ft/lbs. Based on these values, the HP should be as follows for these two points:
404 HP at 8800 rpm and subsequently, 347 HP at 9100. The graph shows approximately 420 HP at 9100 rpm... this is a 73 HP difference. The dip should be BIGGER in the HP line than the one plotted in the Torque line since we are looking at a point above 5252 rpm on the graph.
Now, as a side note: I am not sure what transmission the OP is using in this application, but if it is being pulled in 3rd gear, there is a strong possibility of spinning the tires on the roller and the torque values will be skewed.
#29
It is possible that a dip in spark advance would translate into a dip in performance... but this isn't what I was questioning. The dip CANNOT exist in the torque graph and NOT exist in the same area on the HP graph. Remember that at any position throughout the engine's operational range, from idle to redline, HP and Torque are a mathematical product related to the other. IF you know one value, you can solve for the other.
#30
Yeah the power by mph is a little anorgasmic haha.
Id like to see an rpm sheet if there is one. Do you remember when you get full boost on 3-4 gear?
On the other hand any dyno sheet is usefull.
On the tech things 62mm sxe looks VERY close to the 62MM FMW, thats close enough to the s363.
Still id get 362 sxe over anything if i wanted "single scroll" due to better efficiency islands and better choke line on the lower pressure ratios.
On the sxe vs s362 FMW surge line in very close.
I’m not sure. I just know it really only “hits” when vtec engages. I’ll upload some data logs for you when I get the chance.
#31
#32
Let's look at the X-axis here and see where it started to record. Looks to be at about 62mph. OP says GSR trans in 4th. So, RPM would be figured between 32 and 3500 at the time this pull began. Seems to coincide with where torque and hp cross in the beginning (if that's where VTEC should be kicking in, around 4400). If following that, RPM would be CRAZY high at peak power levels on here. Unless I'm off track? I dunno. Something seems weird, just don't know what. Would RPM dyno measure differently than MPH scale-wise? I'm not sure if I even know how to phrase my question. Lol
#33
2x0, for the record... I am NOT suggesting that the OP has fabricated this dyno graph. My questions were merely to understand why the discrepancies existed. The tuner and the OP were present when the dyno pulls occurred... we H-T members were not. My experience with the DynoJet system suggests that since the tach signal was not being received solidly by the dyno stack/computer, the measuring of the performance/output of the engine is relegated to calculating HP only by measuring the time necessary to accelerate the dyno roller from the starting speed to the terminal speed. The "dip" in torque is likely a computer glitch and therefore, not "fixable" by the tuner AND not an issue the OP should be concerned with.
#34
The torque was all over the place when we were dynoing. Like I said the car runs very smooth and a dip like that would be very noticeable
supracharger
10-06-2008 05:05 PM
adlert82
05-04-2005 01:54 PM
