b20 turbo project... oil pressure sensor problem
what will happen if i dont run the oil temp sensor (i think its the oil temp sensor.. its the green plug on the back of the engine near the oil filter) on my b20 setup. Im using a b18 wiring harness and the sensor comes on the b18 but not the b20 im using. how will it affect my setup?
Re: b20 turbo project... oil pressure sensor problem
Thats the oil pressure sending unit, it should be plugged in. Just get a brass T and put the T into the block and then just put on the oil pressure sending unit into the T as well as an oil feed line to go to your turbo.
es_racing
11-22-2016 07:48 AM
