B18cr turbo plans
B18cr turbo plans
I am about tired of my NA motor and just picked up a jdm b18c. im looking to get 300-350hp and also have it a reliable daily driver. I havent done a turbo on a b series and definetly not one with high compression. here is what i looking at getting:
garrett t3/t04e 57 trim 8-12psi
cast manifold unless i find a deal on a ramhorn
tial 38mm wastegate and bov
hondata s300
750 injectors and fuel pump
my questions are should i get arp head bolts? different headgasket? wideband?
It will be tuned by a great tuner here. just want to have a decently fast daily driver and i realize things go wrong and s*** happens haha always does. let me know what you guys think. and what numbers i should be around.
hondata s300
Re: B18cr turbo plans
ok good deal, had some ppl tell me i would but hardly found anything on here about it. i have a exedy stage 2 from my other motor still is perfect. will i make bout 300-350 and be reliable with a good tune?
You do not need head studs but i would suggest spending the $130 and for the head gasket you dont need to replace it but if you do cometic. I like having my widewide band so i can keep an eye on my afr's. My car put down 380 whp on stock everything and 11psi
why no wideband? after blowing an engine due to running lean condtions without noticing... there not that expensive and since you running hondata whoch has the datalogging capability... why not?
head studs are cheap insurance...pick them up
Head studs are cheap and easy enough so i could definetly get those. i heard alot of ppl saying they use oem head gaskets even running with alot of more hp than i wish to have so i probably stay with the oem. So wideband maybe maybe not? i heard it only takes one tank of bad gas to f*** your motor up and i want it reliable so ill take a look into them, they are decently cheap. anything else you guys thinkin of i should look into?
I would do head studs. No need to replace your head gasket if the one you have is good. Jut replace 1 head bolt/stud at a time and tq it down. Then you will need a clutch because your clutch will not hold the tq. If your wheels hook with that kind of power slip city. You dont NEED a widebad, but its always nice to have. I watch mine more than any other gauge. If you need a headgasket, oem all the way!
