b18c1 dizzy issue when car get hot
ok i was at the track last weekn an made some runs, after 2 runs the dizzy went out and car wasnt get any spark, after a hour later it started up. Any body had this issue an how can i fix this? this is ona boosted b18c1 runing 400 hp.
did you have this problem and put a brand new dizzy and the problem continued? i was gonna guess your ignitor or coil is bad but you say you changed the dizzy. are you using a resistor box for your injectors?
i dont think that has anything to do with the dizzy.. i had 3 dizzy on it an it ran for awhile till it gets hot, then the igniter went out on all 3 of them.
Re: (high_octane)
it does, it happened to me consistently for 4 or 5 months. i kept thinking its the dizzy cuz as soon as i drove around and turned the car off, it wouldn't turn back on. then i wouldn't have spark. i changed the dizzy several times and even the engine harness. then finally i put a new resistor box and the car has started up everytime ever since.
Re: (high_octane)
i got it a few times. if i turned the car on and off, the code would go away. but after i changed the resistor box the code never came back. check ur yellow/black wire going to the dizzy plug before u change the box out though. thats the ignition output signal wire.
well i use one of my buddys resistor box off his car and still nothing, then took his dizzy off an tryed it an it fired rite up. so it the dizzy ,got my dizzy from dizzy king today an tryed it didnt work they sent me a bad dizzy... **** sucks.
B17ACRX
01-19-2009 09:27 PM
twentyhurtz
12-07-2006 05:16 PM
hondatuner123
02-23-2006 12:04 PM
