B18B turbo(what internals to run)
I finally got enough money to get a turbo i have about 1600 dollars and its just enough to get the whole turbo setup, but i dont know if i can run stock internals. I have 117000 miles on my well maintained integra ls.
Re: B18B turbo(what internals to run) (DOHCon15s)
just get the turbo kit run 8-9psi and you should be fine with typical fmu run more boost with a better fuel system
Re: B18B turbo(what internals to run) (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">just get the turbo kit run 8-9psi and you should be fine with typical fmu run more boost with a better fuel system </TD></TR></TABLE>
and no tuning whatsoever? cool!
Re: B18B turbo(what internals to run) (XDEep)
ls will handle with bone kit really not much tuning if you just by a prefab kit not much you can tune
Smarter than you
like viren said, if ur just running a basic kit w/ fmu, inline fuel pump and stock injectors there isn't gonna be any tuning you can really do. but i just had to comment that its gonna be tough putting together a nice kit for 1600$ unless u have alot of hook ups on parts and fabrication.
Re: B18B turbo(what internals to run) (DIRep)
if you wanted to do a mild build what would be a good set up. i have about $2000 to put into the ls, any suggestions?
