Are b16a cams or gsr cams better for boost?
what do u fell are better performing cams for boost? i am converting my LS turbo to LS/Vtec turbo, getting a feel for what to go for
thanks
wade
thanks
wade
Re: Are b16a cams or gsr cams better for boost? (wade)
i did some research but it seems that the gsr and b16 cams are the same cams.
send gen b16 and gsr are the same i beleive first gen b16 are different
Re: Are b16a cams or gsr cams better for boost? (calvinPGMFI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by calvinPGMFI »</TD></TR><TR><TD CLASS="quote">i did some research but it seems that the gsr and b16 cams are the same cams.
send gen b16 and gsr are the same i beleive first gen b16 are different</TD></TR></TABLE>
You couldn't be more wrong.
These are the stock specs of the GSR and B16 cams from Crower.com.
Part # Description Advertised Duration, Duration @ .050" Gross Lift w/1.55
Stock Specs from Civic Si
Int-265 mid Exh-267 mid Int-219 mid Exh-214 mid Int-.412 mid Exh-.379 mid
Stock Specs from GSR
Int-274 mid Exh-276 mid Int-230 mid Exh-216 mid Int-.423 mid Exh-.378 mid
Just compare the specs. You can definetly tell they're not the same cam.
