b16 valve spring and retainers install
can someone give me a link to valve springs and retainer installation with the head still installed? anything will help even with it off. I just want a general idea. I will be installing some as soon as I return
Re: b16 valve spring and retainers install (rudebwoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudebwoy »</TD></TR><TR><TD CLASS="quote">can someone give me a link to valve springs and retainer installation with the head still installed? anything will help even with it off. I just want a general idea. I will be installing some as soon as I return</TD></TR></TABLE>
here you go https://honda-tech.com/zerothread?id=474849 thank me, Bauley Civic, and the thread starter later. https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: b16 valve spring and retainers install (TeStUdO)
That write-up is an excellent one, but it is with the head removed. To install with the head still on the engine, you will need an air compressor and a fitting to fit the spark plug hole to keep the valve from dropping. You can also use wet nylon rope fed into the spark plug hole with the piston at TDC to keep the valve from falling into the cylinder. Make sure you leave a little rope hanging out so you can retrieve it when your finished, lol.
Opps, there is another excellent write-up a few posts down of install with head on. |
