b16 turbo(south africa)
hey all
suprise suprise
yes we do it big in south africa too
ive gathered the following parts and wanted your take and appeal on them as a setup
B16a6 block with b16a6 head
cp 83mm 9:1 cr pistons
83mm cometic hg
LA cast iron 80mm sleeves
scat rods with arp rod bolts(in the motor)
walboro 255lph fuel pump(in car)
acl race bearings(just put them in)
arp head stud kit
blox stg 2 cams
with blox valve train kit and
megan racing cam gears
power chamber intake(jdm)
precision 650cc injectors
act heavy duty street clutch kit
turbonetics t3/4 with .63 exh housing(stg v exh wheel)
custom downpipe and exhaust(76mm)
turbonetics evolution wastegate(0.8 bar spring)
tial 50mm bov
custom core intercooler and 63mm boost pipes
ram horn turbo manifold(custom)
dicktator engine management(local does the trick here)
so what u think?and what is the max boost i can push?
what power would you estimate me making at just under 1 bar boost?
im hoping for 240 kw on the wheels at 0.8 bar boost (sorry we measure in different units)
and what kind of redlines will i see aswell as when will boost kick in through the rev range?
thanks guys
you should check out hondaracing.za.org
if you got time too
suprise suprise
83mm cometic hg
arp head stud kit
blox stg 2 cams
tial 50mm bov
thanks guys
if you got time too
19sec beast
06-01-2005 04:30 PM
