B16 Turbo compression results
I felt the need to check out my compression due to whitish smoke coming out the exhaust at startup, so I was suspicious of the rings.
But anyway, dry
its:
Tranny - 175 - 165 - 145 - 160
and with the oil trick
Tranny - 180 - 180 - 165 -180
So Im pretty sure my rings are being the suck, I mean she runs good still and boost great, but now I know somethings up.
Compression is lowered to 9.2:1, so its not in the 200+'s Ive seen, but its close to the 184 optimum when its wet.
Anyone have any comments, or input?
The one is lower, so that has me concerned
But anyway, dry
its:
Re: B16 Turbo compression results (SpeedingHatch)
If this is a stock B16, those numbers are fairly low. #4 didn't really increase much with the addition of the oil, but you gained some 20psi in the other 3 chambers. Looks like your rings may be on the way out.
Re: B16 Turbo compression results (VTC_CiViC)
As I said, I have 9.2:1 compression pistons if that matters
Id assume that would lower the numbers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpeedingHatch »</TD></TR><TR><TD CLASS="quote">As I said, I have 9.2:1 compression pistons if that matters
Id assume that would lower the numbers</TD></TR></TABLE>
Opps, I missed that
Those numbers aren't too far off from 9.2:1, but I'd still wonder why you gained a nice chunk of compression after you did a wet test.
Opps, I missed that
turbo-crx
10-10-2007 09:29 AM
Brandon31386
07-23-2006 10:56 PM
tek_civic
08-17-2003 06:29 PM
