B16 TURBO CAMS WHICH ONES BEST?
Anyone got any recommendations on best cams for a B16 running T3 turbo @ 1 bar, Wossner pistons, stock rods & bottom end. It does have AEM FIC & RC 400cc injectors so reasonably mappable.
Any help would be appreciated. |
Re: B16 TURBO CAMS WHICH ONES BEST?
typeR cams always do a great job.
Blox B or Skunk2 Stage 2.
you are so limited with 400cc injectors and EMS i wouldnt even bother with cams
Skunk2 Pro3s are the best cams.... /sarcasm.
But seriously though, different cams work BEST on different SETUPS. Tell us your COMPLETE SETUP. |
im gonna hi-jack on this thread instead of making a new thread which is almost the same
my build is this B16 head stock everything has GSR cams in it Skunk2 intake mani ported runners and ported TB opening to 68mm 68mm TB (blox) precesion 1000s block B18a 81.5mm tuner toy rods weisco pistons 9.5:1 comp AFI top mount Tial 44mm precesion SC 54 turbo 3 inch DP to 3 inch exhaust 2.5 ic pipes all around im throwing in a super tech valve springs and retainers and im wondering should i go with stage 2 skunk2 cams which are very pricey or go with Blox B cams? im trying to get as close to 500 (on pump). |
