b16 turbo bogging
91 crx si
b16 with headstuds and gsr cams 750cc RC injectors 60 trim on a full race kit no cels driving around in vacuum the car runs great, if you give it throttle though and start to boost it bogs. acording to the hondata it goes lean during the bogging/breaking up. it is hard to tell if vtec is engaging or not due to this symptom. twice i have let it get to temp from cold and then get three good pulls out of it b4 this starts happening. any ideas would be super as i am at my wits end. thanks in advance |
Re: b16 turbo bogging
Did you have it tuned? What map sensor are you running?
turns out it was a bad spark plug wire! NGK wire at that.
| All times are GMT -8. The time now is 11:50 AM. |
