b16 stock, comp. at 10:4 safe to turbo? (searched)
hello guyz i just got a complete jdm b16a 2gen but its cable. want to swap this into my 93 eg. my question is. would it be safe to turbo. the compression is at 10:4?
and can i just get low compression pistons and use my stock b16 rods?
plus what do u think i should do about the cable/hydro situation? should i get a conversion or sell the cable tranny and get a hydro?
can u guyz help me on what to do with this situation? the motor is obd0 and i need to put it in my obd1 car. i know i need a different distributor, wiring harness, driver side bracket, shift linkage. would my obd1 vtec wiring harness work? i've searched.
thanks in advance.
thanks in advance.
compressions fine...and just sell the cable and get a hydro...
yes stock pistons would work if you wanted to use aftermarket pistons but if your going through the trouble for the pistons just get some eagle rods for 300
Re: b16 stock, comp. at 10:4 safe to turbo? (egturbo)
Sell it all and put it toward a true SIR2 swap or something else that's OBD1...
By the time you're done swapping transmissions, sensors, distributors, injectors, ECU's, etc... you will wish you had scrapped the OBD0 swap from the get go.
Good luck.
Good luck.
Re: b16 stock, comp. at 10:4 safe to turbo? (HybridKOOP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridKOOP »</TD></TR><TR><TD CLASS="quote">Sell it all and put it toward a true SIR2 swap or something else that's OBD1...
Good luck.</TD></TR></TABLE>
isnt my motor a true sirII? it jdm and umm the block says b16a only and the serial #'s on the bottom start with a 5??? am i correct?
what will i need to change if i were to install it in my eg?
Re: (quik sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol »</TD></TR><TR><TD CLASS="quote">dude don't worry about it...all ya need is motor mounts....as long as its a complete change over</TD></TR></TABLE>
yep its still on the crx i bought the whole car. and imma piece out the rest of the crx. all it needs is a motor and change out the front end to jdm conversion. imma put the b16 motor in my car.
so change to hydro tranny. what about the wiring harness, dizzy, linkage? its obdo
Re: (egturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egturbo »</TD></TR><TR><TD CLASS="quote">
so change to hydro tranny. what about the wiring harness, dizzy, linkage? its obdo</TD></TR></TABLE>
SiR and SiRII are trim levels. So yeah, you probably do have an SiRII motor.
Your confusing SiRII with 2nd gen.
Yodi71
02-11-2019 12:21 PM
crazyass05
05-21-2004 09:35 PM
