B16 500whp EM1 Dyno Chart
Finally satisfied with my numbers on my Si on my first trip to the rollers. I wont bore you with lots of talk just facts. Enjoy!!!
- Darton Sleeved 85mm B16
- CP 9.8:1 Pistons
- Eagle Rods
- No P&P
- Skunk2 Complete valvetrain with oversized valves, bronze guides and everything in between.
- Skunk2 Tunner2 cams & camgears
- Skunk2 Pro IM & 70mm TB
- AEM fuel rail with 1000cc ID & Walbro fuel pump
- 2 1/2 intercooler tubing
- Vortec BOV
- Tial 40mm WG
- Custom made Equal lenght manifold
- GT35 .63 hot side
- 3 in full downpipe exhaust all the way to the back to a 3 in straight Dynomax pipe.
- Hondata S300
- GREDDY Profec Spec II
- Full weight SI daily driven with A/C & P/S
93 octane 422@20psi
C116 536@31psi
Powerband is a little bogus but since it was the 1st dyno tune we didnt wanna push it. Powerband dropoff can be fixed with some cam adjustments. Mixture and timing were conservative for reliability so a little more can be squeezed out but Im happy.
- CP 9.8:1 Pistons
- Eagle Rods
- No P&P
- Vortec BOV
- Tial 40mm WG
- GT35 .63 hot side
- Hondata S300
93 octane 422@20psi
C116 536@31psi
Re: B16 500whp EM1 Dyno Chart
Yes sir. Bored to 85mm
Updates for this post here:
https://honda-tech.com/forums/showth...ght=stc+reaper
very nice what problems did you run into man
i had some as well fuel pressure and voltage are falling off up top on me but my a1000 is probly taking a **** on me lol
I had problems with the intercooler and my compressor housing let go of the bolts so..... We fixed that and got to the results above. Cant ask more for a B16 with stock fuel lines and a little walbro255 with ID1000s.
true only differance i see between us is fuel
what duty are you seeing with them id's, and base pressure
i was at 89% at a base of 70psi on my little 1000's
i love it when people say you need 2200's to make the descent power lol
well just found my issue lol 9v at the pump, and 7v at higher rpm damm street VR is toast oh well
love to see nice b16 builds man, and you have one keep up the work and squeeez the power out
surprized it didnt make more power, i think that .63 hotside is killing power... those cams are pretty big for that small of a hotside imo
Moderator
If he really was looking for more than 100whp or more, it would make more sense to use a larger exhaust wheel such as the 74mm in .63A/R than to just simply putting a larger housing on the same size wheel. Yes, some have argued that "spool" characteristics may change by as little as 300rpms, but still doesn't address that the larger wheel would be more beneficial than a larger housing (all other things being equal).
LocoJoe doesn't ever plan to be at a peaky 600whp. He'd rather be at over 500whp for 99% of the powerband, hence his reasoning for staying with the smaller 71mm exhaust wheel and .63A/R housing for his purpose of the B16. Remember, he originally wanted only 550whp PEAK, so, I'm sure he's happy. He not afraid to push boost, which is nice to have for a change instead of these 10psi at 500whp peak with no powerband at all with 80lbs/min with a 6765 or similar setup.
This was as good as an in-between as one could ask for for the build.
