B-Series "Dogbox"
Old 02-08-2006, 12:56 AM
Who is Mr Robot?
wantboost's Avatar
Default B-Series "Dogbox"
im curious to see if any companies make what i call "dogboxes" for the b-series motors. that is, straight cut gears that replace the helical setup for the 5 forward gears. i know alot of the dsm guys have these available to them but havent really seen any around for us honda guys. i know a company called CTC makes a set but their site is down at the moment.
Thanks
Old 02-08-2006, 05:13 AM
splitime's Avatar
Default Re: B-Series "Dogbox" (wantboost)
Gear speed's site seems down also... but here's a HT link with some info...
https://honda-tech.com/zerothread?id=1085206
Old 02-08-2006, 05:26 AM
tony1's Avatar
Default Re: B-Series "Dogbox" (splitime)
CTC is no longer in business, Libertys has the only ones that have proven themselves so far. 15 8.5 or better passes and counting in Chuck Seitsingers car.
Old 02-08-2006, 06:35 AM
wade's Avatar
Default Re: B-Series "Dogbox" (tony1)
these would rock my world for daily use, i think im going to do eeeet since it would be so practical, haha JK
back to topic, yea i have heard about Chucks car and setup, i would like to see it in real life sometime!
Old 02-08-2006, 06:48 AM
Who is Mr Robot?
wantboost's Avatar
Default Re: B-Series "Dogbox" (wade)
the liberty's kit includes 1-4 for like 3950 or something. i was really hoping to find a kit that retained 5th gear
Old 02-08-2006, 07:22 AM
2001accord's Avatar
I bought a saenz gearset 1-5 straight cut for my H series. but they also had a dog box option, i believe they are finished with the b series design\testing. The 5th gear is 1:1 though or 1.05:1, so no overdrive. (gearset was $1700, R&P $1900, and will assemble it for you at no charge)
Alfred Nolan- contact there, can help you, they tested them and so far had 1100whp and still going.
Alfred's info:
dadwithgas@hotmail.com
http://www.saenzperformance.com
Old 02-08-2006, 07:24 AM
mike1114's Avatar
Default Re: B-Series "Dogbox" (2001accord)
quiafe does. they always have an add for it in the import magazines.
Its like $2600 for the gears, $15K for a 6 speed sequential setup.
Old 02-08-2006, 07:46 AM
underpressure02's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">CTC is no longer in business, Libertys has the only ones that have proven themselves so far. 15 8.5 or better passes and counting in Chuck Seitsingers car.</TD></TR></TABLE>
Tony doesn't G-force also make a dog cut gears for the b series?
Old 02-08-2006, 07:52 AM
tony1's Avatar
Default Re: B-Series "Dogbox" (underpressure02)
Yes, they do, but i don't know any info on them. I know for sure the liberty stuff works, that's why i mentioned it. There are others out there, Saenz, PAR, G-Force, etc., but i can't say how well they work.
Old 02-08-2006, 08:47 AM
HybridKOOP's Avatar
What is the main benefit to these gears? (aside from strength)
Old 02-08-2006, 08:59 AM
2001accord's Avatar
Default Re: B-Series "Dogbox" (HybridKOOP)
strength, reliability, gear ratio's available. Plus have a sweet whine going down the street.
Old 02-08-2006, 09:01 AM
z6
z6's Avatar
I dont know of many people having trouble with stock gears sets...y fix what isnt broke
Old 02-08-2006, 09:02 AM
HybridKOOP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2001accord &raquo;</TD></TR><TR><TD CLASS="quote">strength, reliability, gear ratio's available. Plus have a sweet whine going down the street.</TD></TR></TABLE>
I knew about the strength, custom ratios etc... even the whine... but there has to be some sort of advantage to the actual way the gear is cut...
Old 02-08-2006, 10:05 AM
FATBOYeg6's Avatar
what do you mean by the way the gear is cut? if you mean the teeth, a "dogbox" has straight cut gears as opposed to helical. i know the straight cut teeth are stonger, but i also heard they loose less power through the drivetrain because of the striaght cut also. can anyone confirm this?
Old 02-08-2006, 10:18 AM
Black R's Avatar
Default Re: (z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 &raquo;</TD></TR><TR><TD CLASS="quote">I dont know of many people having trouble with stock gears sets...y fix what isnt broke</TD></TR></TABLE>
Clutchless shifting cuts down in et. get it?
Sequential dogbox = t3h pwn!!11
Old 02-08-2006, 02:01 PM
Who is Mr Robot?
wantboost's Avatar
Default Re: (Black R)
main advantage is strength and the ability to shift quicker... all you need is an ignition cut setup and you can upshift without taking your foot off of the gas...same with down shift. also the whine isnt that bad believe it or not
Old 02-08-2006, 04:01 PM
Dee
Dee's Avatar
Default Re: (wantboost)
Those awesome Aussie engineers
http://www.par-engineering.com/
http://www.ppgearbox.com.au/
Old 02-08-2006, 04:06 PM
sc4dr's Avatar
Default Re: (Dee)
Shift like a motorcycle, sounds killer
Old 02-08-2006, 04:45 PM
h22 civic's Avatar
Default Re: (sc4dr)
check my sig for liberty gears they have been around for many years and got some good stuff
jasperjohn
02-07-2009 01:24 AM
DEPintheCurve
01-09-2009 12:45 PM
jimmyisback
Honda Civic (2001 - 2005)
10-28-2008 03:04 PM
iheartmyeg6
03-22-2007 06:29 PM
SDturbogsr
26
08-30-2003 08:28 AM
Quick Reply: B-Series "Dogbox"
