Re: AZ_CIVIC'S Build, Testing Things, ETC.
Originally Posted by AZ_CIVIC
(Post 51883518)
Head gasket was not sealing, made 1 pull just on the gate pressure and at about 8500 rpms it sprayed water everywhere but we weren’t sure where. I cleaned everything up and we tested it a little bit and I noticed coolant pushing out of the overflow. Pulled the plugs and they looked good besides number 3 had a little residue. So we are 100% it’s at least the head gasket so we pulled the motor. |
:cry:
damn :(
Oem head gasket? What torque ft lb arp head studs? |
It was a JE head gasket that was being used and we found out that it is for sure a head gasket failure on cylinder 3. Not really sure what caused this but a new head gasket is going on, I guess it was a freak accident or something but the motor is going back together and will go back into the car. |
(Post 51884970)
(Post 51884970)
It was a JE head gasket that was being used.
(Post 51884970)
(Post 51884970)
A JE HEAD GASKET
Oh... Shit... Tell me that is was a questionable knockoff and not the 125 dollar bastard that I've got wedged between my block and head.. JE Proseal? You've just put me in a panic.. |
Originally Posted by Txdragon
(Post 51885142)
It’s the JE proseal which is recommended for Darton sleeves as well, my motor is step decked and oringed. We are going to test cylinder 3 injectors just to make sure nothing is clogged and I just bought a new emap canister cause mine was getting clogged. |
Ok then. Chalk this up to the infamous Honda temper tantrum!
(Post 51885275)
any pics of broken headgasket?
I at least want to post a video of when the motor fired up LOL.
(Post 51886238)
(Post 51886622)
Nice! sounds like a helicopter. lol!
I was really looking forward to see this run last Sunday. The mishap on the other car was a bummer as well. |
Originally Posted by stin1
(Post 51887011)
Over 3 weeks with no updates? I'm sitting at the keyboard like :scared:
Originally Posted by DaX
(Post 51904601)
What sensor did you decide on using for coolant pressure?
Originally Posted by khrys771
(Post 51925914)
Been pretty busy working on another car I got from the auction but now that I’m done I got a little done on the race car. I built another breather catch can that will be sitting under the car where the stock fuel tank used to be. I had so much pressure that would build up I had oil push out of the catch can up front. Now I did do a bunch of restrictions on the catch can up front and haven’t tested it but my buddy did the same thing I did and it stopped the issues we were having.
This will help a lot because the line will be about 10 feet so I can relieve the pressure and the cool thing is that it will vent out of the old gas filler neck. https://cimg3.ibsrv.net/gimg/honda-t...6d56460ca.jpeg https://cimg4.ibsrv.net/gimg/honda-t...ff664d51b.jpeg https://cimg5.ibsrv.net/gimg/honda-t...faf664962.jpeg https://cimg8.ibsrv.net/gimg/honda-t...417d9f071.jpeg https://cimg9.ibsrv.net/gimg/honda-t...f6cb712ef.jpeg |
Very nice! Looks like it belongs.
(Post 51938456)
Hard to tell from the photos,but is your Rear setup as Staging Brake Only,or is it T'd/Y'd for all 4 corners to still be foot brake?
