average spool time of your gt series turbos
sorry guys i searched but just want to see what the average spool time and what motor you have at full boost with you'r GT Series turbo trying to compare what i would want to put on my DC2 GSR
Re: average spool time of your gt series turbos (speedlabx2005)
what goals do you have whp wise? also is your motor built?
this will help everyone narrow down your size of turbo.
im looking for about 350whp and am looking at the gt2871R
Re: average spool time of your gt series turbos (Integra21)
yeah i got a built gsr motor still breaking it in. HP goals are 500 but I was curious because i daily drive and if the turbo fully spools at 5000 rpms its not going to be fun to drive then i will lower my HP goals.
yea my guess is a 500whp turbo will not be spooling before 5k...but i will leave that to the turbo experts
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedlabx2005 »</TD></TR><TR><TD CLASS="quote">yeah i got a built gsr motor still breaking it in. HP goals are 500 but I was curious because i daily drive and if the turbo fully spools at 5000 rpms its not going to be fun to drive then i will lower my HP goals. </TD></TR></TABLE>
5000 isn't so bad, just downshift.
http://forums.evans-tuning.com...=2330
3000+ RPM's of power is a damned nice powerband.
gt2871r .86, stock b16 starts around 3500ish, hits full boost around 4500ish also dependent on gear and load.
Dude, if u want 500hp as a daily driver and also want full spool by 5krpm u not gonna be able to use that power down cos u won't have traction at that low rpm... U'd be spinning like a bitch. Its somtimes good to power coming in later to help u with traction progressively..
Re: average spool time of your gt series turbos (swlabhot)
i see what you guys are saying later spool better traction maybe a cheaper turbo like a SC61 with a lower AR would be best for me
I had the assumption that the gt30r got full boost at 4500rpms bummer
I'm going to be running a fully built GSR block, darton sleeves, 84mm cp pistons. and a built b16 head. I'm looking for around 500whp. I've been looking at the SC-61 and GT35R. I know the GT35R is ball bearing, all that's going to do is make it spool a little faster, so i was thinking about just getting the GT35 to save about $500. Are the specs on these turbos the same? Anyone have any suggestions on what A/R to go with for more top end power from like 5500-6000 until shifting? Thanks
a hx35/40 hyrbid would def fit all your needs....youd just be able to keep it hooked up w/ the sudeen onset of power...and they are a lot cheaper...then all the baller snails
Re: (speedlabx2005)
If you want a gt turbo and with your goals, I would get a gt3076, sick power band!!! You will not be driving at 500hp all the time I hope. The gt3076 makes a beautiful power band at a lower boost like 15psi on pump gas.
Look at these dyno graphs.
(GT3076)-->http://forums.evans-tuning.com...gt30r
and GT30r-->http://forums.evans-tuning.com...gt30r
That would be so fun to drive..
EcHoB18C1
08-12-2009 02:56 AM
