autometer air/fuel guage reading
okay....i know people say that the autometer air/fuel guage sucks and all, but when hitting boost, where should that guage be, in the red, yellow, or green?
of course not in the red since that is lean, but about the stoich or rich?
Re: autometer air/fuel guage reading (93hb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hb »</TD></TR><TR><TD CLASS="quote">okay....i know people say that the autometer air/fuel guage sucks and all, but when hitting boost, where should that guage be, in the red, yellow, or green?
of course not in the red since that is lean, but about the stoich or rich?</TD></TR></TABLE>
You will want it in green since you are boosted.
Re: (t3to4e)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t3to4e »</TD></TR><TR><TD CLASS="quote">would want it just above orange in the green not to far</TD></TR></TABLE>
If its in anything besides the green when you are boosting you are probably running lean.............................
New User
Re: (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO »</TD></TR><TR><TD CLASS="quote">
If its in anything besides the green when you are boosting you are probably running lean.............................</TD></TR></TABLE>
yep, because autometer says due to heavy acceleartion it should always be in green
Re: (integrx)
autometer afr gauge is the biggest waste of money, we tested it w/ my wideband, it just bounced around the same every time we change the AFR from rich to lean.
DONT WASTE YOUR MONEY.
HT's Biggest Loser
Re: (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase »</TD></TR><TR><TD CLASS="quote">autometer afr gauge is the biggest waste of money, we tested it w/ my wideband, it just bounced around the same every time we change the AFR from rich to lean.
DONT WASTE YOUR MONEY. </TD></TR></TABLE>
Best advice you will ever hear about the atuometer AF guage, its a true P.O.S.... most peopel buy it cause it looks pretty
Re: (SIXTYdashONE)
Mine said it was running sooooo lean, that I started adding fuel to make it run richer, but the readings didn't change. I ended up adding so much fuel the car would bog at 1psi, I leaned it back out after all the guys on H-T told me to and what-do-ya know !!! I'm looking into a wideband.. Prob. hit the dnyo first and use there wideband.
Re: (Mase)
Also bear in mind that even if the gauge is in the green range showing rich conditions; in boosted applications you could still be running LEAN, so technically its misleading you thinking your OK but in reality you could still blow your engine.
when i hit full throttle and the wastegate opens on mine it looks like it goes straight lean and boggs out falling on its face...yet i dont get any knocking on my setup. its an uberchipped p28 on a b16 running 5lbs. any ideas...do u think im too rich? i checked the plugs and they show that they are starting to get the normal brown but are clean as heck...any ideas?
e jay one
Northern California (Sales)
16
01-15-2007 03:01 PM
JdelMsolG
08-23-2006 04:30 PM
