auto with turbo?
anyone has their auto boosted ? i'm want to do this, perfer to be as quick as a LS w/ i/h/e. i have a LS, can people recomend me what i need to do ? also just answer this question first. does the greedy street legal kit put me where i want to be if not does the JRSC? if so then is all i need a toruqe converter and the kit if i want to run minimal boost. oh if you didn't know i'm AUTO
[Modified by integrx, 1:50 AM 3/20/2002] |
Re: auto with turbo? (integrx)
Turbos on automatics are very fun. http://images.zeroforum.com/smile/emsmile.gif
38 views and no one can tell me what i have to do to run turbo. i'm a newbi and my question is just what engine work has to be done to my car so the motor doesn't blow if i boost at 6psi.
no engine work at all...with that setting....
Hey guy,
I HAD and auto teg that was boosted. The person did a pretty CRAPPY job and blew my engine, turbo and tranny. I've been paying bills since (about 500 bucks a month) and I am still waiting for the turbo. Few things to note: 1)AUTO TEG WITH TURBO WAS REALLLLLY FUN http://images.zeroforum.com/smile/emsmile.gif 2)Torque converter is not going to help strengthen the tranny. If I were you I would just keep it at low boost (7-8 lbs), get a HUGE AFTERMARKET TRANNY COOLER, and pray that that little tranny can take the pressure. If used in moderation, you will be having a blast. 3)You still won't launch for crap, but since you keep that foot on the peddle, you will be hauling. On the highway at 50 MPH, my tires CHIRPED HARDCORE when smashed into passing gear. Bottom line - auto tranny is weak. A good long term and somewhat pricey investment would be to get a stronger auto tranny from LEVEL10, or at least get the "bullet proof" kit (300 parts + 8 hours labor). TAKE CARE OF YOUR TRANNY! REPLACE IT, BEEF IT UP and above all, COOL THAT MUTHA! good luck. |
BTW, you will be faster than another auto with IHE. Get a small turbo unless you are planning to beef up that tranny and run higher boost. I had the Revhard stage 2. T3/T4 if I were you, I would get a smaller one. Save on lagg and money.
my .02 |
thank you all for the reply, i know now that i'll need the turbo kit(of course), a torque converter, and better tranny cooler.
and as for the teg with i/h/e, i knew i could be an auto, but i was refering to a stick LS with i/h/e. i will do more research and hope to be boosted in 1/2 a year. just wondering how much were you boosting when you blew your engine,turbo,tranny? any one got sites to aftermarket tranny cooler ? [Modified by integrx, 5:44 PM 3/20/2002] |
I think that it was somewhere around 3 lbs. It was because fluids were leaking and everything was just set up like crap. Watch your fuel curves also.
Good luck. |
| All times are GMT -8. The time now is 06:04 AM. |
