Apexi Power Fc
Apexi Power Fc
Yo guys im running a a 95 gsr turbo with a power fc and 740cc injectors with a t3/60-1 (15-20psi) and i was needing some base maps to start tuning my setup, let me know what u guys have thanks alot.
mike
mike
Re: Apexi Power Fc (turbo gsr)
they don't make any base makps. you have to start from gorund 0 for it. That's why we alreays suggest a hondata because it came with basemaps from hondata not to mention there are a lot out as well....
you can have it done by xs engineering for $100.they did mine by what i told them i had and it was almost perfect from the get-go.i spent only 2 hours on the dyno fine tuning it.
Re: Apexi Power Fc (swlabhot)
damn lol that sucks, all the instructions and manuals that came with it are in japanese and i can't read any of it except here and there it will say "FC Commander" haha im in TN anybody close at all maybe within like georgia or something let me know fellas, thanks again
mike
mike
Not much in this english manual but in case you need it and haven't got it already.
http://apexi-usa.com/productdo...C.pdf
awesome man, i dont know about this power fc stuff i will think about your trade if i cant get anything going with it, but thanks for the help guys!!
mike
mike
Re: Apexi Power Fc (turbotypeR)
where is this place? and do u know if they make like a obd1 to obd2 harness because the ****** ecu is obd2 it sucks *** so i need some clips and hard wire or something i dunno let me know what u would do thanks man
mike
mike
maps are different on all cars...even ones with similar setups...I would go to the Apexi website and find a Power Excel dealer near you. wouldn't advice using someone elses maps...the may not be right.
Re: Apexi Power Fc (MiraiZ)
oh ok im talking to u in 2 different post do u have aim if so IM me mjsloveshsp copy paste that **** cause its weird lol but it would be quicker if u do thanks
xs is in texas.you DO NOT have to take your car there to be tuned.send them a list of your setup and they will put in base maps that are pretty dang close.then you go to the dyno and fine tune it for your car.i spent two hours on the dyno with mine and that is only because i wanted more power.we hardly touched it.i could have been through in 30 minutes.the power fc is obd2 and they offer obd2 to obd1 adaptors.
hell yea man ive got an adapter on its way, 245 shipped so it wasnt to bad. So i just send them my Power fc ecu and the list of my mods and they program it or will they just send me some maps? how much is it let me know and i appreciate all your help again if u have aim my sn is mjsloveshsp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotypeR »</TD></TR><TR><TD CLASS="quote">xs is in texas.you DO NOT have to take your car there to be tuned.send them a list of your setup and they will put in base maps that are pretty dang close.then you go to the dyno and fine tune it for your car.i spent two hours on the dyno with mine and that is only because i wanted more power.we hardly touched it.i could have been through in 30 minutes.the power fc is obd2 and they offer obd2 to obd1 adaptors. </TD></TR></TABLE>
I thought XS was in California?
they used to charge $100,i assume it is still the same.they program the base maps in.you have full control over the ignition maps and a limited control over the fuel maps.if the "limited control is not enough,you can alter the map voltage to change the base map.make sure whomever you have tune it on the dyno when you get it back has used one before.that will make it much easier.ed from dynotuner.net did mine and he knew it like the back of his hand.
Re: Apexi Power Fc (ladysman)
XS is in Cal. Theres a Power Excel shop in Houston, the shop name is Carboy. I would say power fc is there specialty!!! I purchased and had it tuned there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman »</TD></TR><TR><TD CLASS="quote">
I thought XS was in California?</TD></TR></TABLE>
sorry.i had a brain fart.i must have been thinking of someone else!
yeah.call and ask for koji if they will let you talk to him.his accent is very hard to understand but he is very nice and very good with the fc.he tuned mine and gave me good support on hte phone.
did this ever work? i just called XS and they said that the car SHOULD turn on. i bought the unit used. and couple weeks ago i hooked it up and it wouldnt turn on. ima re-try it tonight. but hopefully i didnt get a DUD!!
Re: Apexi Power Fc (baonest)
i dunno i went broke all of the sudden and had to stop buying parts and **** i havent had a chance to send them mine yet, i think what they do is just program you a base map, i heard if it is not programed by a distributor like XS engineering that it wont turn on, you have to have some codes broken or some **** i dunno good luck though man
mike
mike
