apexi gauges + gauge pod...?
fixing to buy 3 apexi el series 60mm gauges, would they fit in the full auto meter pillar pod thingy. or does apexi make pods for their gauges?? i don't think they do, thats why i'm curious. thanx
Re: apexi gauges + gauge pod...? (98civicguy)
I run 2 60mm apex gauges in my pillar. You will need to trim the holes with a dremel or file and they will fit nicely----they will have a little overlap, but look really good.
Re: apexi gauges + gauge pod...? (MachAF)
No not properly 2in 5/8s is bigger then 60mm and 2in is to small you can buy apexi pillar mounts though
Re: apexi gauges + gauge pod...? (turbozxi)
no pix but i've done it.. fits perfect after you trim it a little with a dremel.. your going to have to "STUFF" it in there.. it will flex the plastic out a little bit...
