is this apex IC good for my set up???
well I worked out a trade plus cash for an APEX intercooler for my 95 teg. well I was wondering if this IC would be good for my setup which includes:
lsvtec with 81.5mm cp pistons, eagle rods, acl bearings, cometic HG, supertech valvetrain, vic X, RLD mani w/3" Dp and open tump tube, tial wg, hks bov, GT3076r w .82 ar and hondata s300.
well the numbers on the IC is 534-t002 and here is a pic of my motor and the IC, the IC is 24x10 and I am hoping for about 400+hp on stock sleeves and injectors I am not really sure what size to go with I was thiking 7##cc
Re: is this apex IC good for my set up??? (dansred2000si)
nice looking setup man! and yea that IC will be able to handle 400WHP for sure.. it just may be kinda interesting to run the charge pipes to it thought seeing as how the inlets are angled backwards.. but i'm sure you can figure something out.
as for injectors i'd go for PTE 880's if i were you and wanting around 400whp.
Re: is this apex IC good for my set up??? (moores55)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by moores55 »</TD></TR><TR><TD CLASS="quote">Hey there is nothign wrong with miller..... After 5 or 6 bud lights.</TD></TR></TABLE>
Why'd you torture your tastebuds several times before you feed them something great? I don't get it.
OP - the thing to look at is the inside. If the internal fins are more dense than the denser outside rows, it will be more than enough.
nice setup man. intercooler looks big enough, but the inlet/outlet positioning may be a bia. i would go ahead and do 1000cc injectors since they are about the same price and most 7xx cc's are also peak and hold. if you dont want to put in a resistor box for peak and hold injectors the largest non peak/hold i know of are RC 750's
guymosiris
11-30-2003 09:07 PM
