Anyone's OMNI Power 4Bar MAP sensor take a poop yet?
#27
Re: Anyone's OMNI Power 4Bar MAP sensor take a **** yet? (JDogg)
are their any good, factory style mounted map sensors out there besides hondata and omni?
#30
Re: Anyone's OMNI Power 4Bar MAP sensor take a **** yet? (wantboost)
back from the dead, has omni fixed the problem? I've been lookin into buying a map sensor, and would rather have a stock looking sensor, instead of installing a gm 3 bar. thank you
#33
Re: Anyone's OMNI Power 4Bar MAP sensor take a **** yet? (twkdCD595)
I use these on a pretty regualar basis lately and have not been having any issues at all.
#35
Re: Anyone's OMNI Power 4Bar MAP sensor take a **** yet? (JAYSEM Society)
The OEM sensors I've modded I always sealed around the port (sensor glued to bottom plate). Omni seems to have them jammed in there, with the bottom case plug weakly sealed shut. The only way to break mine are to rip one mount ear clean off, or shatter the actual sensor.
What they really need is to put a spacer between the top and the sensor inside the case.
#36
Re: Anyone's OMNI Power 4Bar MAP sensor take a **** yet? (HiProfile)
glad I took the time to open my stock map gut it out and place motarola 4 bar inside and then epoxy it shut..no problems and a LOT cheaper. Sorry for your guys issue. I've had brand name parts take a dump on me..
#40
Re: Anyone's OMNI Power 4Bar MAP sensor take a **** yet? (H.A.R.T B18C1EG6)
i know this is an old thread,
but mabey somone could help me,
i need to setup my omni 4 map does anyone have the following values?
This is what I've used
Map min voltage
Map max voltage
map filter
Load offset
Load scalar
Frequency
thanks
Map min voltage
Map max voltage
map filter
Load offset
Load scalar
Frequency
thanks
#41
Re: Anyone's OMNI Power 4Bar MAP sensor take a poop yet?
the scalar is 838
the offset is 31
mbar @ 5v is 4221
v @ standard atmospheric is 1.172
5v @ 47.14 lbs relitive to atmospheric press
the offset is 31
mbar @ 5v is 4221
#42
Directly from omnipowerusa.com:
Hondata S300/S200/S200 Settings:
Scalar 838
Offset 31
Crome Settings:
Min: 34.7 mbar
Max: 4000 mbar
Koeov: 1.23 volts
Neptune Settings:
Scalar: 838
Offset: 31
AEM Settings:
MIN=0
MAX=4.8
LOAD OFF SET=0
LOAD SCALAR=4.0
Voltage to pressure (KPA) conversion
P= pressure in KPA 4 bar = 400 KPA
Voltage out/signal = 5 X (.002421 X P - .00842)
Atmosphere equals 1 bar or 100 KPA = 5 X (.002421 X 100 - .00842) = 1.168 volts @ 1 bar or 100 KPA
Also an update to the original post... We have been selling omnipower & hondata 4 bar map sensors for over a year now & ran them on our vehicles without one problem!
Scalar 838
Offset 31
Crome Settings:
Min: 34.7 mbar
Max: 4000 mbar
Koeov: 1.23 volts
Neptune Settings:
Scalar: 838
Offset: 31
AEM Settings:
MIN=0
MAX=4.8
LOAD OFF SET=0
LOAD SCALAR=4.0
#43
mtber, if I were to buy an Omni MAP sensor, you bet I will be only buying them from you...LOL Last thing I want is to go to a local vendor and end up buying some "old store stock"... That's why I hate new products that completely blow up into pieces or fail miserably when they first come out, and later down the road, they make it into a good working product.. ie: AEM C2DI...hah I still won't be buying them until 5 years later or something.
#46
Scalar 838
Offset 31
Crome Settings:
Min: 34.7 mbar
Max: 4000 mbar
Koeov: 1.23 volts
Neptune Settings:
Scalar: 838
Offset: 31
AEM Settings:
MIN=0
MAX=4.8
LOAD OFF SET=0
LOAD SCALAR=4.0
Scalar 838
Offset 31
Crome Settings:
Min: 34.7 mbar
Max: 4000 mbar
Koeov: 1.23 volts
Neptune Settings:
Scalar: 838
Offset: 31
AEM Settings:
MIN=0
MAX=4.8
LOAD OFF SET=0
LOAD SCALAR=4.0
PS: 1 bar is not 1 atm. 1 atm is 14.7psi. 1 bar is 14.5psi If you are doing to run the math, it might as well be done correctly.
hatchinprogress
11-23-2004 08:21 PM
