Anyone using Turbo XS quad stage boost controller with AEM.
Anyone using the quad stage boost controller with AEM? How do you have it set up? I'm looking to use this set up, but want insight on how to run all the wiring to the EMS.
Re: Anyone using Turbo XS quad stage boost controller with AEM. (slvrslepr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slvrslepr »</TD></TR><TR><TD CLASS="quote">Anyone using the quad stage boost controller with AEM? How do you have it set up? I'm looking to use this set up, but want insight on how to run all the wiring to the EMS.</TD></TR></TABLE>
I am, you have to figure out how you want it to be clicked on for differnt stages. I have mine set to VSS, but you can set it up too, rpm,vss,load,collent temp, whatever you want, figure out first how you want it triggereed, then wire it in
Re: Anyone using Turbo XS quad stage boost controller with AEM. (vtekthis)
do you use relays to wire in the boost dcontroller or run directly to the drivers.
Re: Anyone using Turbo XS quad stage boost controller with AEM. (ILLICON5000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILLICON5000 »</TD></TR><TR><TD CLASS="quote">dude it's much easier to just run the GM boost control solenoid. probobly cheaper too</TD></TR></TABLE>
x2
x2
just use a boost control solenoid valve, i can get you a valve just like aem sells for $50 wire directly to ems and help you on getting it set up correctly. you can have 40+ different levels of boost
