Anyone using the Profec B Spec II with their GReddy kit?
There are three ports....COM, NO, and NC.
Where does each port connect to? I know that one port is left unused...
I was told that the "COM" port isn't used for an internal wastegate setup.
GReddy 18g kit...
GReddy 18g kit...
Re: Anyone using the Profec B Spec II with their GReddy kit? (FBP Si 2000)
hey Jackson maybe snap a pic?
_____________________________$$$____$$____________ _____$$$__________ _$$$$$$$$$$$$$___$$__________$$$__$$$$____________ ___$$$$$$$$_______ $$$$$$$$$$$$$$$_$$$$________$$$$__$$$$___________$ $$_$$$$$$$$$$_____ $$_$$$____$$$$$_$$$$________$$$$__$$$$__________$$ $$__$$$$$$$$$$____ __$$$$_____$$$$_$$$$_______$$$$___$$$$_________$$$ $$__$$$$_$$$$$$___ _$$$$$___$$$$$__$$$$_______$$$$___$$$$$______$$$$$ $$__$$$$___$$$$$__ _$$$$__$$$$$____$$$$_______$$$$__$$$$$$_____$$$$$$ $___$$$$____$$$$__ _$$$$$$$$$______$$$$______$$$$___$$$$$$$__$$$$$$$$ $___$$$_____$$$$__ $$$$$$$_________$$$$______$$$$___$$$$$$$$$$$$__$$$ ___$$$$_____$$$$__ $$$$$$$_________$$$$_____$$$$____$$$_$$$$$$$___$$$ ___$$$$____$$$$___ $$$$$$$$$$$_____$$$$_____$$$$____$$$___$$$____$$$$ ___$$$___$$$$$$___ _$$$_$$$$$$$$___$$$$____$$$$$____$$$__________$$$_ ___$$$$$$$$$$_____ _$$$_____$$$$$___$$$$__$$$$$$____$$$__________$$$_ __$$$$$$$_________ _$$$____$$$$$$___$$$$$$$$$$$____$$$$__________$$$_ _$$$$_____________ _$$$$$$$$$$$$$____$$$$$$_$$$$___$$$__________$$$__ __$$$_____________ $$$$$$$$$$$________$$$___$$$$___$$$__________$$___ __$$$$____________ $$$$$$$___________________________________________ __$$$$____________ _$$_______________________________________________ __$$$_____________
The "COM" port is used for both actuator and external wastegate type... For internal wastegate setup, the "NO" port connects to the turbo, and "com" port connects to the actuator.
For external wastegate setups, "NC" port connects to the turbo, and "COM" port connects to the top of the wastegate.
Hope that helps
Hope that helps
Re: Anyone using the Profec B Spec II with their GReddy kit? (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 »</TD></TR><TR><TD CLASS="quote">The "COM" port is used for both actuator and external wastegate type... For internal wastegate setup, the "NO" port connects to the turbo, and "com" port connects to the actuator.
Hope that helps
What if there is no port on the turbo? The only port I have is for the actuator...so would the "NO" port connect to a pressure source (IM)?
Hope that helps
