Anyone use two belt tensioners?
Old 08-02-2003, 01:52 PM
93LSivic's Avatar
Default Anyone use two belt tensioners?
I was looking at an old vid I have of Gardella's civic. He runs a additional stock tensioner on the front of the block and I was thinking of doing this for peace of mind. Obviously this is for high rpms, but Im sure it'll wouldnt hurt us guys that only goto 8500 also.
Any thoughts?
Old 08-02-2003, 02:13 PM
RenoRacing's Avatar
Default Re: Anyone use two belt tensioners? (93LSivic)
My friends and i have thought about making an additional timing belt tensioner that is simpler, more like the type that are used on serpentine belts, something that just pushes onto the belt and could just bolt to the front of the block.
Old 08-02-2003, 02:28 PM
intekragsr's Avatar
Default Re: Anyone use two belt tensioners? (HavokRacing)
this sounds interesting. Any pics? For somereason, i cannot visualize 2 tensioners.
Old 08-02-2003, 03:14 PM
93LSivic's Avatar
Default Re: Anyone use two belt tensioners? (intekragsr)
Damn, I cant find any pics. Hopefully I will get the video coverted and be able to show it.
It was a fabbed up bracket where the power steering would be just holding a stock tensioner.
Old 08-02-2003, 04:29 PM
tony1's Avatar
Gary did this because he had problems with the timing belt jumping while the car was on the two step. He runs very big cams and has a very violent two step on that car to help spool the monster turbo he runs. We have never had a problem with that on our car and i'm sure you'll never run into that on a street car. Just make sure you tension the belt right...
Old 08-03-2003, 08:18 AM
93LSivic's Avatar
Default Re: Anyone use two belt tensioners? (tony1)
Thanks for the info Tony. Im sure it had a lot to do with his setup, and was there for a good reason. I think it would look pretty cool on a street car though. I notice sometimes how much deflection there is on some motors that run w/o the covers.....looks kinda scary.
2k.civic.si
09-25-2010 08:09 AM
slide inside
10-22-2009 09:25 AM
chimmychongaz
08-07-2008 06:43 PM
accord20o1
05-30-2006 03:44 PM
InTeGrA B18b1
08-20-2003 07:57 AM
Quick Reply: Anyone use two belt tensioners?
