Anyone know torque specs for Pauter rod bolts? tony1 or motormatrix?
OK I am assembling my motor and if memory serves me correct the Pauter rod bolts are 35ft-lbs with oil , the rod bolts are 220k tensile and 5/16th bolts. tony1 or matormatrix? If not will call Pauter tomorrow thanks!
Re: Anyone know torque specs for Pauter rod bolts? tony1 or motormatrix? (Boostfed)
Call up pauter they would better help you on something like that than taking someones word for it
Re: Anyone know torque specs for Pauter rod bolts? tony1 or motormatrix? (MotorMatrix.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com »</TD></TR><TR><TD CLASS="quote">they are 50ft lbs with oil if I'm not mistaken.</TD></TR></TABLE>
Now I know that is too much they are between 35-38ft-lbs, I will call Pauter tomorrow, thanks anyway.
I am a bad person
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed »</TD></TR><TR><TD CLASS="quote">
Now I know that is too much they are between 35-38ft-lbs, I will call Pauter tomorrow, thanks anyway.</TD></TR></TABLE>
I'm 100% sure its atleast 50. actually I should ask if they are the 220k bolts?? which is what mine are standard. keep in mind crowers are 45lbs so they cant be less then crowers.
Modified by MotorMatrix.com at 12:28 AM 6/9/2003
I'm 100% sure its 50. actually I should ask if they are the 220k bolts?? which is what mine are standard.</TD></TR></TABLE>
220k right on the rod bolts, they are 3/8 bolts, seems too high, but I will double check. Thanks.
Modified by MotorMatrix.com at 12:28 AM 6/9/2003</TD></TR></TABLE>
Ah I called Pauter today and confirmed that the torque spec on their B16A rod bolts ared 36 ft-lbs, I asked about the B18C they said 50ft-lbs, I asked why does it have a bigger bolt like 3/8 they confirmed they did, WTF? I asked why the B18C had 3/8 and the B16A had only 5/16, the tech told me the B16A are based off the same program as the D16s, WTF? Oh well I torqued them to what they said, also with oil. Thanks for the help anyways.
god damn it. That pisses me off. so what size are the eagle rod bolts (the 2000 arp's)? arent the 5/16ths?
So what is the the strength of the b16a pauter rod bolts? if the b18c is 220k.
Re: Anyone know torque specs for Pauter rod bolts? tony1 or motormatrix? (Dublocivic)
damn eagle rods are torqued down to 28 ft/lb..what a puny eheheh
Pauter is def the ****..
stan
stan
Re: Anyone know torque specs for Pauter rod bolts? tony1 or motormatrix? (Flamenco-T)
I have Pauters but I sure want the 3/8th's bolt.. Heavy *** pauters going to 10k with a 5/16th's rod bolt .. makes me feel a little sketchy.
