anyone with GReddy kits, need helping with changing injector wires and oilpan
Re: anyone with GReddy kits, need helping with changing injector wires and oilpan (puffy)
What are you doing to your injectors? Each injector has only 2 wires, one + and one -. The leftmost wire to each injector is the positive just so you know. And yes there are like 12 bolts around the oil pan and I belive there might be one attached to the tranny you'll need to loosen as well. It should be pretty straight forward, just look.
BMW Güdentyte
Calm down puffy. There's plenty of time for peeps to respond.
Yes, the injector wires are color coded. Are you installing the injector connector that the kit came with because the wires are both black?
Yes, those are the only bolts that holds up the oil pan.
Do the GReddy injectors come with some kind of pigtail or something? They don't plug straight into the existing injector harness?
So if the harness for greddy injectors are both colored black, how can you tell which on goes where on your stock gsr?
TIA
oil pan nuts are metric a 10 or 12mm socket should be used, set the socket to loosen and turn counter clockwise, repeat untill each nut is removed from oil pan, there is also a retaining bracket/cover that uses same size or similar size nuts it is covering a little section of the pan and the tranny. make sure to use a new gasket or gasket sealant when replacing the pan. installation is the reverse of the above steps. sorry that i am not able to write my instructions any slower. you can call the acura oil pan help phone if this does not work tel:1-800-OIL-PANS ask for the giggler pin department.
BMW Güdentyte
Re: anyone with GReddy kits, need helping with changing injector wires and oilpan (FBP Si 2000)
Lay the two connectors, old(connected) and new, side by side, copy how the original connector is seated on the injector (only goes one way). Cut the left wire of the original connector,splice it, then connect on the left wire of the greddy one. Then do the same thing on the right one, then connect it to the right wire of the greddy one. Same steps as the rest of the connectors.
