Anyone with a Fluidyne radiator(especially for a 5th gen Lude)- please help me- I need another fan f
I still haven't found a fan that is thinner than a FAL fan. I can't buy another Fluidyne fan because it is too thick and will not fit between the radiator and the turbo. Anyone know who makes a VERY thin, PAPERTHIN electric fan? I don't care what it looks like, just as long as it is thin and ~11". Please help a guy out, I don't want to be running only 1 fan
Re: Anyone with a Fluidyne radiator(especially for a 5th gen Lude)- please help me- I need another f
Hmm I have these fans, way thinner than my FAL fans were:
the only one i can think of is the FAL trimline fan model 112...its height is 2-7/8"
how much was that fan dustin and where did u get it?
I bought them from a local car parts place. They were $60 each.
i got my fans from summit racing. they are reallyyyyy thin and are dual 11". i decided to put them in the same location that dustin put his. i tried to find the fans on summitracing.com but i couldnt find them and i am not sure of the part number, if you have the catalogue it is in the section with radiators and such. they run about $180ish and you can also get these fans with an adjustable thermostat for i believe 225-250.
[Modified by GudeH23a, 8:55 PM 4/19/2002]
I think thinnest FAL fan in still 2.5....
Thinnest fan I've seen are the SPAL fans.. at 2.05"
Get a SPAL fan, I have one in my CRX. it really thin, I think around 2 inches or so. and when it comes on, its almost as loud as the turbo.
http://www.racesearch.com/gen_html/manuf/10867.html ...part # 30100375 is the 12" slimline fan.... use this link for the specifications http://www.jaycorptech.com/shop/shop...Cooling+Fansns
[Modified by Quaalude, 6:11 PM 4/20/2002]
Well, I wonder which I need though- push style or puller style? I think I am going to mount them between the radiator and the turbo(basically like the stock setup).
Also,in case I didn't have enough room, could I make a pusher/puller fan into the other? It seems like the 11" SPAL pusher and puller fan are the same in every demension, and power, just that they flow different directions.
Thanks!
Thanks!
This is a stupi d question, but do you keep the fan that is in your stock radiator when you get one of these?
Spocko
03-11-2002 05:49 PM
