Anyone every have there turbo glowing red hot??
Re: Anyone every have there turbo glowing red hot?? (mplex2000)
I have heard of people being able to see their turbine side (hot side) spinning inside the housing...just what I heard.
Re: Anyone every have there turbo glowing red hot?? (syeve)
that is pretty crazy
I am asking because my friend has a turbo hatch and we pulled over at a gas station because it was smoking alot and his manifold and his turbo where cherry red hot....we let it cool down and drove right home.
Is this a bad thing --what causes it not enough oil getting to the turbo???
i told him maybe he should check his oil feed line
Re: Anyone every have there turbo glowing red hot?? (NeXtLeVeL_TyPe_R)
my bud's bone stock 94 Saab 9000 Aero's turbo did this. the turbine housing glwed red. its no big deal tho, just make sure your turbo timer is working properly
New User
This happens with almost all turbos. They are made to withstand this kind of heat. Don't worry about it. If you haven't seen your turbo glowing hot, it's because you've never popped your hood at night right after turning the engine off.
Re: Anyone every have there turbo glowing red hot?? (dbman96)
New User
Yea even if the manifold is glowing hot too....thats surprising and comforting at the same time
he and i are both running maxrev manifolds
I am gald to see this is somewhat normal i though he may have been running into a big problem
Re: Anyone every have there turbo glowing red hot?? (Bryson)
I have yet to see my turbo glow...... even at night after a long drive with lots of boosting...
Then again mabye because mines oil/water cooled, and possibly also beacause its big? (t3/t04e)
where do you get the water cool stuff from? Do you use water cooled and oil cooled, or is it one or the other?
Re: Anyone every have there turbo glowing red hot?? (HondaCutter)
its in the turbo. some turbo are just oil cooled. and some are water and oil cooled the turbo has 2 passages around the center shaft so oil and water wont get mixed up
the water cooling comes from taping onto the coolent hose lines. if you are asking that
[Modified by lamchop0000, 10:19 AM 5/31/2002]
yeh some most factory turbo's run both oil and coolent to cool the turbo. and i think some aftermarket turbos do also. tapping on to the coolent... i think most people use the line from the throttle body, but im not sure if theres anywhere else you could tap onto.
Re: Anyone every have there turbo glowing red hot?? (lamchop0000)
ive seen a dyno run of a supra tt where the wastegate started the glow and u hear that cool wastegate sound after he let off the gas
