anybody run a good number with a tiny turbo>
Old 12-25-2006, 08:07 AM
97grnrs's Avatar
Default anybody run a good number with a tiny turbo>
just wondering. i ran a 12.8 with a 14b at only 11 psi last season in my hatch.. now im runnin a 300zx t25 in my zc crx and im hoping to do low 12's or high 11's.. prob around 16psi or so.. anyone else run a decent number on a small turbo
Old 12-25-2006, 08:15 AM
Man U FTW
Schister66's Avatar
what is your idea of a decent number?? I dont think you're going to see more than 275whp on that turbo no matter how hard you push it...
Old 12-25-2006, 08:22 AM
spoolin turbo s's Avatar
Default Re: (Schister66)
get a t3 off a thunderbird and you could hit 300whp on that zc
Old 12-25-2006, 08:53 AM
RC000E's Avatar
Default Re: (spoolin turbo s)
for the ZC turbo setup. A certain shop in the Greensburg area of PA call ZC's slug motors because they think they are better than everyone else. I like seeing someone put together a nice budget setup that produces results. Good job bro.
Old 12-25-2006, 11:37 AM
HiProfile's Avatar
Default Re: (RC000E)
I'm hoping next year to get some times from a built d16z6 with the tiny 45trim .42/.48 turbo. I'm hoping to run it a few times at 15+ psi before switching over to a larger snail. The problem finding smaller turbo numbers is that Honda guys tend to get a larger turbo before they get a better MAP sensor. 6psi small turbo --> 6psi larger turbo --> 12psi larger turbo, etc. I'm hoping to max out this small turbo, push as much power in a sohc as most stock-block b-series motors, but have very little lag. My stock d16z6 spooled my t3/t04b s-trim at 3k, and had 11psi at 4k. Was great for power, but spooled a bit slow for daily driving & an LX trans.
As far as the smaller turbos not making as much power, think of the old 'na vs boost' issue. Its not as much power, but its a borad torque curve. Unless you get a custom FD or mix gears, all d-series trans drop the revs quite a bit between shifts. You can also modulate boost in a smaller turbo much easier. Even if you pull too much throttle when the wheels start screaming, you still can get back on it and build boost very quick.
Old 12-25-2006, 03:42 PM
97grnrs's Avatar
Default Re: anybody run a good number with a tiny turbo> (97grnrs)
im not really concerned with dyno numbers.. just track time, i broke into 12's with the 14b . my goal is 11's wit the t25 running alot more boost.. so well see.. if the zc blows im dropping a a6 in
Old 12-25-2006, 04:22 PM
Skilz10179's Avatar
You do know a T25 will make less power that the 14b did, right?
Old 12-26-2006, 01:14 PM
97grnrs's Avatar
Default Re: anybody run a good number with a tiny turbo> (Skilz10179)
ya i know.. but ill run more boost to make up for it. its a 300zx t25 not a dsm one if that makes a diff..
Old 12-26-2006, 06:26 PM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">im not really concerned with dyno numbers.. just track time, i broke into 12's with the 14b . my goal is 11's wit the t25 running alot more boost.. so well see.. if the zc blows im dropping a a6 in </TD></TR></TABLE>
You'll probably just end up blowing hot air into your engine since you'll be way out of the turbo's efficiency range.
You say you ran 12's... but there are a lot of other factors that come into play. You could have a 1700lb chassis for all we know so very little hp could easily get you into the 12's.
Old 12-26-2006, 07:49 PM
97grnrs's Avatar
Default Re: anybody run a good number with a tiny turbo> (PrecisionH23a)
ya . it was in my 91 hatch.. interior gutted . ls motor and 14b turbo homemade kit. now i have a zc in my crx which is crazy gutted.. doors and all and is prob lighter than the hatch was..so i should be able to put down low 12's high 11's if i get traction. im runnin the t25 @ 16psi right now.. it seems to run great except the lack of traction even with 225 50 15 BFG drag radials.
Old 12-26-2006, 10:46 PM
TallKyle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">ya . it was in my 91 hatch.. interior gutted . ls motor and 14b turbo homemade kit. now i have a zc in my crx which is crazy gutted.. doors and all and is prob lighter than the hatch was..so i should be able to put down low 12's high 11's if i get traction. im runnin the t25 @ 16psi right now.. it seems to run great except the lack of traction even with 225 50 15 BFG drag radials. </TD></TR></TABLE>
good luck on that. Its a lot harder doing it , then it is saying it.
Old 12-27-2006, 01:48 PM
97grnrs's Avatar
Default Re: anybody run a good number with a tiny turbo> (TallKyle)
well i already did 12's so its not that hard. with a homemade setup . so 12's in this crx will be cake.. im just hoping for 11's
MugenFlaredCRX
03-27-2005 09:56 PM
hatchinprogress
21
07-17-2004 06:57 PM
miketurbohonda
04-11-2004 02:51 AM
solely92hatch
15
05-03-2003 12:06 AM
APEXI Si
01-29-2003 06:47 AM
Quick Reply: anybody run a good number with a tiny turbo>
