anybody ever see 10:1 compression on a turbo motor?
i can get a fully built bottom end , it has sleeves, pistons, rods, but the compression is 10:1 its in a 1.6 block i was wondering if anybody ever had that compression and ran boost? if so how it work out for you? and what kind of hp numbers or 1/4 mile times? how much boost you running? thanks justin
Re: anybody ever see 10:1 compression on a turbo motor? (gnu1.6Si)
am running a h23 with 10.2:1 comp ill get some high boost numbers soon i just ordered me a h22 tranny after i get that here i get it in and ill hit the dyno
Guest
Posts: n/a
Re: (Tinker219)
i WAS running 10:1 on turbo, but i had to get new pistons b/c of some slight detonation, i couldn't re-use the pistons, i wanted 10:1 again, but all i could find was 9.2:1 H22 pistons on such short notice, but i did get to go up to 89mm bore though
Re: (T-sohctec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-sohctec »</TD></TR><TR><TD CLASS="quote">ever hear of a turbo type-R.
10:1 is fine just don't skimp on things like injectors, management & tuning.</TD></TR></TABLE>
definately dont skimp on those! most important things imo.
Re: (evoeone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evoeone »</TD></TR><TR><TD CLASS="quote">i think colin, (ekb18c1) from rpm nyc does 10:1 flat tops, and like 400whp, oh yeah bad *** its all in the tuning</TD></TR></TABLE>
Nope! it's ekb18c not ekb18c1... and it was 426...
10:1 is a good compression for a turbo car especially for the street. I can't wait till I go 84mm with 11.5:1 comp.
1 Post
Re: (ekb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18c »</TD></TR><TR><TD CLASS="quote">
I can't wait till I go 84mm with 11.5:1 comp. </TD></TR></TABLE>
Wow sounds like fun!
Anyway, 83mm 10:1 JE flat tops for me
I will be running 78mm 10:1 JE flat tops in my Built ZC.
It will help this small motor spool up a quite large turbo. (SC50).
Re: (ekb18c)
10:1 is a good compression for a turbo car especially for the street. I can't wait till I go 84mm with 11.5:1 comp. </TD></TR></TABLE>
do the same tuning techniques stay when u raise cr that high for turbo??12.1-12.5 a/f ratio and .5degree retardation of timing(dynamic(in the ecu?)) oer lb of boost??
Re: Re: (Turbo E)
yo colins what is the turn around time on a a.e.bs or golden eagle block 95 h22 going high boost wich do ya recomend godzilla sleeves or aebs?
