Any thoughts on Nippon Racing pistons for D16?
Hello!
I've read a lot of Nippon Racing vs YCP and so on discussions here and on d-series.org but all of them are too old.
Just looking if someone have tried the oh-so-controversial chinese Nippon Racing pistons. Those would be installed on a D16 DOHC ZC engine, due to the big combustion chamber, I can't use YCP Vitaras. The goal is to reach ~350 crank HP or so, I think those pistons would work fine.
Re: Any thoughts on Nippon Racing pistons for D16?
From what Ive heard they work fine but when building a block I say spend the couple extra hundred and get some real pistons, worth every penny why cut corners... do it right the first time
Those Nippons do have a nice fat ringland which I'm sure would hold up. If you ran into any issues tuning though, I think you'd be better off with a forged piston. I don't know how many people actually have experience with them- but a lot of people recommend them for all motor over forced induction application. One person I saw noted the difference in aluminum quality/strength. YCP used AC8 grade aluminum whereas Nippon uses a more common and less durable aluminum? I guess it's a plus to be higher compression though. I am using Wiseco forged pistons (8.8:1) in my D16 build, but wish I'd have found a higher CR setup.
Thank you for your advices 2kdrift and bergercurtis!
Here were I live, is very difficult to buy any "import" piston like CP, Wiseco, JE, etc. Due to our customs limitations, but I can get the Nippon Racing ones. Also, CP/JE doesn't have any piston for my application because of the big combustion chamber of my engine (Z6 or Y8 pistons will drop CR less than 8:1) and I'm looking a CR between 8.5 and 9.5
Anyways, I will try to get some CP or JE. Thanks!!
Yeah the DOHC ZC is a weird animal. I don't know if you plan to do so, but you might be able to deck the head/block some to raise it.. Then you'd need adjustable cam gears though. I think it'd be easier just to get a higher CR piston/rod setup, but it's up to you. 350 crank isn't too high. I can't imagine you're straining them too much. What fuel are you going to use?
Well, I'm afraid on decking the head or block since it's a rare engine here. Actually, my engine was built 3 years ago, and lasted that 3 years on a heavy foot over the gas pedal. Piston 3 melted after 22.000km, an injector failed or something, because that was the only one broken, on 17-18psi of a Garrett GT28RS.
Engine was built with SUPER MEGA HIPER chinese pistons, chinese as the printed model on the piston head says MP6 instead of PM6 hahaha.
