:: ::: Any one have pictures of how they ran their turbo coolant lines? ::: ::
I'm curious to see how everyone is running their coolant lines to their turbo.
Re: :: ::: Any one have pictures of how they ran their turbo coolant lines? ::: :: (ncervantes)
Take the coolant line off the IM, and run that to the turbo, then run the water return back the to the IM.
Re: :: ::: Any one have pictures of how they ran their turbo coolant lines? ::: :: (Cray91)
You don't suggest having the water go through the radiator before going back to the motor? Why add the extra heat straight to the motor? Sorry but that seems like taking a risk of having your motor run hotter than it should? Sorry i'm still new to this as you can tell....LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ncervantes »</TD></TR><TR><TD CLASS="quote">You don't suggest having the water go through the radiator before going back to the motor? Why add the extra heat straight to the motor? Sorry but that seems like taking a risk of having your motor run hotter than it should? Sorry i'm still new to this as you can tell....LOL
</TD></TR></TABLE> thats why if i were you i wouldnt run coolent lines (it will effect the engine's cooling system)
You don't need them. But the lines are meant to be run for a reason. They are not on there just as an "option".
Adding the heat to the coolant will not be too big of a deal, the thermostat will just open quicker and stay open longer to compensate.
