any new 6262 dyno numbers?
Old 03-20-2011, 06:47 PM
  #26
laosonick's Avatar
Default Re: any new 6262 dyno numbers?
730whp on a mustang dyno. 32psi
Old 03-21-2011, 06:01 AM
  #27
rs250nut's Avatar
Originally Posted by MadVTI
Some big numbers there guys, off to dyno on thurs here in UK with a Sleeved B16 with journal 6262 .82 turbo. Hoping to crack 600hp at crank on 30ish PSI. Keep u posted.
Are you racing this in the Hks? Have a similar setup myself so be good to see where you have full boost by, 6000rpm?
Old 03-21-2011, 07:51 AM
  #28
4cylfiend's Avatar
A buddy of mine just dyno'd his piston/rods K series with a DBB6262 and made 610@25 psi on E85.
Old 03-21-2011, 10:29 AM
  #29
ls_on_boost's Avatar
Originally Posted by AllShowNoGo727
ls vtec 84mm 6262 ball bearing 63. ar ported s cover number in sig.
what psi?
Old 03-21-2011, 10:49 AM
  #30
MadVTI's Avatar
Its a customers car mate, its got a bar by 5200ish, laggy through gears though but its a 1600 with big pipe mani so thats expected. Its bloody quick even at a bar though. lol Roll on thurs, just a note to people before fitting there turbo, check the 4 bolts that are in the core that hold the compressor back plate on. On the last 3 turbo's I have checked they were loose. Some leak oil from these holes, lol. Core must be drilled into oilways from factory.
il keep u posted on numbers. MARC
Old 03-21-2011, 09:33 PM
  #31
BLaCKWiDoWSi's Avatar
Took the girlfriends car to the dyno tonight.
Boost controller was fluctuating just a little bit at higher rpms. This is just on pump gas.
Big thanks to Dwight and Ricky at Stage 6 Motorsports for the fabrication!
Thanks Mase for the tuning late at night!!
Jason B. aka Macguyver for the late nights putting everything together in the garage with BOB.
Henro for the tires!! LMAO! It was for a good cause!
Adam at MAPerformance.com for the turbo about 1 and a half years ago! Great guy and good customer service
More to come once the fuel pump and new regulator come in!
Now I'm going to have to upgrade my own car!!! Can't have the girlfriend faster than me!
Old 03-22-2011, 11:48 AM
  #32
fmfkid250's Avatar
I made 680@28 (dynojet) PSI Basic B motor type r cams. C16. I really liked this turbo.
It was only Reading like 23psi in hondata.
Old 03-27-2011, 07:24 AM
  #33
Rukusmasta2's Avatar
want one of these turbos, :-)
Old 03-27-2011, 09:17 AM
  #34
Blown90hatcH's Avatar
Boost controller was fluctuating just a little bit at higher rpms. This is just on pump gas.Now I'm going to have to upgrade my own car!!! Can't have the girlfriend faster than me!
What's the spec on that turbo.....seems super lazy for a 62...full boost around 6k...
Old 03-27-2011, 09:25 AM
  #35
welfarepc's Avatar
my d16 on 20psi and pump gasoline
Old 04-11-2011, 05:01 PM
  #36
bb6guy's Avatar
Bump!! any more numbers?
Old 04-11-2011, 07:09 PM
  #37
riceball777's Avatar
700+AWHP is pretty common in the evo forums with a billet 6262
Old 04-19-2011, 05:32 PM
  #38
B20luda's Avatar
Originally Posted by .CUBISH.
62/62 journal 750hp 30 psi
62/65 bb 825hp 30 psi
2.0 Gsr
dyno sheet? setup?
Old 04-19-2011, 05:42 PM
  #39
b00stedOne's Avatar
i cant wait to get mine tuned. It s golden eagle sleeved b18 block, stock gsr head (gsr cams), ramhorn manifold, jornal bearing 6262 .82ar, 1200cc injectors.........
hope to get over 550whp.
Will have updates within a few weeks hopefully.
Old 06-30-2011, 11:15 AM
  #40
bb6guy's Avatar
Originally Posted by 94GSRMR
371whp 252.8ftlbs 17lbs
Ls/vtec wiseco 9.0:1, eagle rods, go-autoworks ramhorn manifold,
Precision 38mm wastegate, 1000cc injectors
I could have easily done 400 but my duty cycle was at 84% which is prob a vacuum leak but i prob was down 10whp but the turbo is pretty nice on spool.
371whp and 252ftlbs @ 17lbs of boost with a 6262 on a ls/vtec 81mm with type-R cams? man there's something wrong here... better check your compression.
i have a built b18a 81mm block. with same parts as you, just JE pistons are diff. and a stock B16 head stock cams etc... with a 6262 @ 14lbs it put down 375whp 303ftlbs with a 3" CAT and at 17.9-18.2lbs it put down 420whp 332ftlbs
gotta check your car man. you should be making alot more. especially with those Type-R cams.
Old 06-30-2011, 12:31 PM
  #41
98corbeau coupe's Avatar
480 on pump and 625 on c16 limited by my stage 5 clutch..twin disc soon
Old 06-30-2011, 04:30 PM
  #42
RATEDX1's Avatar
810hp @ 28lbs on e85...6262 .82ar....tuned at church dyno...
Old 06-30-2011, 05:34 PM
  #43
bb6guy's Avatar
specs??
Old 06-30-2011, 09:29 PM
  #44
trunkluv's Avatar
any stock 1.8vtec longblocks putting down numbers? i am looking at the journal bearing percisions.. what size would go best with bonestock gsr 62/62 or 62/65? can journal bearings withstand e85 or is ball bearing the only way to go? im trying to go e85 but ball bearings are a lil expensive
Old 06-30-2011, 09:36 PM
  #45
Moderator
TheShodan's Avatar
Very few people if any would ever use such a large peaky turbo on a stock longblock of any combination. Ceramic ball-bearings can work, its really a matter of the use of the car more than anything else.
Old 06-30-2011, 09:57 PM
  #46
trunkluv's Avatar
i have a godspeed t67 right now and seen that another kat on hondatech used a 6262 on a bonestock gsr and got into the high 10's... so prob 6262? heard that 6265 could be overkill on stock longblock
Old 07-01-2011, 02:45 AM
  #47
94GSRMR's Avatar
Hey bb6 i think i mentioned i had 2 exhaust leaks one between turbo and manifold and other between head and manifold..
Old 07-01-2011, 04:39 AM
  #48
DA 4 Lyfe's Avatar
BB 6265/ E85/ 601whp @23PSI
Old 07-01-2011, 02:44 PM
  #49
RATEDX1's Avatar
Originally Posted by bb6guy
specs??
810hp @ 28lbs e85
6262 .82ar vband
jdl topmount turbo kit
dual backdoor intercooler
dual bosch 044 pumps
AEBS closed deck block
9.1 pistons
manley rods with carr bolts
built head
pro1 cams
00 civic si
Old 07-01-2011, 05:06 PM
  #50
BrockB's Avatar
so far 540whp @15psi with a 62/62. the car is in the shop now getting tweaks done so it should be a lot more than this soon
my build thread is here as a better reference: https://honda-tech.com/forums/forced-induction-16/650-whp-bbs-62-turbo-e85-2008-s2000-build-2946132/
Quick Reply: any new 6262 dyno numbers?
