any greddy turbo kit users using a MBC?
i purchased this MBC on ebay http://cgi.ebay.com/ebaymotors...=true . i adjusted the lock nut on the waste gate to about 7 psi, when i installed my MBC, which is set at the lowest setting, i get boost spikes up to 10psi! is it something i did wrong or is it the MBC itself? thanks in advance
I am having the same EXACT problems. After installing it, I had the screw as far out as possible and it spikes up pretty high. I have seen many people use these and have them work so that's why I thought I'd buy it.
My wastegate vacuum line is inline with the turning dial. The bottom nipple of the boost controller pointing down is going to my vacuum manifold.
bump for answers
Btw I am on a custom kit, and not a greddy kit. But that doesn't matter.
bump for answers
the spring may be too long. also be sure the fitting that leads to the turbo has a tiny hole in it. otherwise after you boost once, the WG wont shut. = no bo0st
boostincoupe
01-24-2005 02:31 AM
vu337
06-29-2003 11:36 AM
