Any experience with turbo'd ZC motors. What whp #'s are you guys putting down?
Okay if everything goes well my turbo should be in by the weekend and I want to know if anyone here is running a ZC motor and what kind whp #'s are you guys getting?
I checked homemadeturbo.com but they don't give any #'s for the ZC motor.
I'll be running 8-11lbs. with a 9:1 compression.
There are no dynos around my area so I just want an idea...
Re: Any experience with turbo'd ZC motors. What whp #'s are you guys putting down? (joey1320)
Around 200whp at 10psi is normal I make 196whp at 10psi on my zc sohc.
Dunno your whp numbers, but I have a friend with heavy (compared to your HF) 91 Civic Si and turbo ZC, runs 7-8 psi, and eats ITR powered EG hatchcrap, Muffstank GT, and held his own against a ram air TA until the top of 3rd where he very gently started to pull it.
No comment on the general condition of the cars involved; the TA bit surprised me. Must be the elevation (2600+ ft).
235hp and 189lbft torque on 12psi. Cams at TDC. With Zdyne ecu. t3/t04 turbo (unknown spec). 9:1 pistons.
REDBARON
12-23-2001 12:46 AM
