anti-surge housing for gt35r?
official honda whore
well i bought a gt35r but i want the anti-surge housing and i was wondering where i can get it and how much they usually are? or is there a way to convert mine (by having someone modify it)
Re: anti-surge housing for gt35r?
can you post pics of your hosing? Depending on what you have it can be modified and also you should be able to pick one up from ATPturbo.com
You can have it modified to the older anti-surge style by just drilling the damn thing but it probably be best to just grab a new/used one.
its more than drilling it there is a slit next the compressor wheel that is at the bottom of the holes, i would think you could send your housing to atp and they could do it, i bought my turbo from there and got the antisurge option, atp also sells a cast anti surge housing but its like 270 or something.
You can drill the holes and slot the cover, but you should have just purchased an FP GT35R turbo if you wanted anti-surge..
http://www.forcedperformance.com/merchant2
easiest route is going to be as I suggested and buy an anti-surge compressor housing from precision, atp, or garrett thru a distributor. probably going to run you a few hundred though.
ya it seems atp has them as well as a couple other places
whats the better option of the 2? the drilled one or the cast one?
also does anyone know why the cast atp unit for the 35r is over 100 dollars more?
