Another Starion IC made possible by the fine people at JB-Weld and Ghetto Engineering
New User
Just thought I'd share these with you; this is what I was up all last night doing:
Re: Another Starion IC made possible by the fine people at JB-Weld and Ghetto Engineering (dbman96)
damn that some wild *** ghetto rigging in that engine bay...
New User
Re: Another Starion IC made possible by the fine people at JB-Weld and Ghetto Engineering (b18bturbo
What, you've never seen a DAC custom fitted with an Apex'i blowoff valve and connected to a 2.5" mandrel bend with a 3-2" reducer fitting? Geez, you need to get out more.
it might stay together a week with JB weld with a prayer or two
If anyone is looking for a starion IC with some nice tig welds on it, polished entanks, and mounting brackets for teg/civic, let me know I might have one for sale. TIA.
New User
sweet another custom turbo setup ima do the same as soon as i find that intercooler. are the black hoses you used from home depot,lowe's,etc? another thing i think your intercooler is kinda off center(leaning towards left side of car). cool setup even tho its ghetto
New User
Re: Another Starion IC made possible by the fine people at JB-Weld and Ghetto Engineering (autoLS)
The big black hoses (3-2 reducers) are from home depot; the rest of the connections I made with large diameter radiator hose pieces, which I prefer over the home depot stuff but I ran out of large enough rad. hose to do the job.
The IC is deliberately off center because of the power steering fluid cooling loop in front of the AC condenser; I didn't want to mess with relocating that so I just shifted the IC over a few inches. Symmetry is secondary when you're ghetto engineering.
I pray this isn't planned to be a daily driver. I also hope you got jackstands, because you've got to have a deathwish getting under the car with the stock jack like that.
JB weld cracks, real easily, in my experience, i'd watch it closely if i were you
New User
Re: Another Starion IC made possible by the fine people at JB-Weld and Ghetto Engineering (Phantom)
Ah you crazy "practical" people. The car was only jacked up like that for a moment so I could get the hose onto the compressor output. And I've been daily driving that car with a LOT worse IC piping setup for almost a year of commuting to work now. This is a huge improvement. Well applied JB weld is actually amazingly strong if it's loaded in the right directions.
You truely are my hero! keep it coming!!! (guys this man really is my mentor!)
good work BTW that JB Weld dosnt look that bad. But did the local welder really want that much to do it the right way
New User
Re: Another Starion IC made possible by the fine people at JB-Weld and Ghetto Engineering (On Point)
dude... I'm too cheap to buy real intercooler piping what makes you think I'd go buy a Tial wastegate?
Seriously thought the delta has been fine for me, boost is well controlled and I have no problems with it so I don't see much reason to mess with it.
I had JB Welded my oil return fitting to my oil pan, and it fell off Monday on the way back from getting my DP done. It lasted about 30 minutes max before the JB Weld cracked and f**king oil spewed all over the bottom of my car and all over my new downpipe. Smoking up a storm...
Re: Another Starion IC made possible by the fine people at JB-Weld and Ghetto Engineering (mplex2000
Ever hear of wire loom? Are all of those wires for Piaa Lights? It looks like my friends Piaa setup.
Do us all a favor and don't get under a car supported with just a jack. even for a "second". Someone I know was killed doing just that.
