Am I going to need a re-tune?
I am putting new 9:1 CP pistons in and timing belt/gaskets/seals, I am curious if I will need to have it re tuned? The tuning it had before was fine and set to good specs... Would I or should it not be a problem? thanks
Re: Am I going to need a re-tune? (dangerranger21)
Personally, I don't startup a car or drive it until i have a wideband on it to monitor. If you have that... and can keep an on it... you'll probably be fine to drive to the tuner.
Re: Am I going to need a re-tune? (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime »</TD></TR><TR><TD CLASS="quote">Personally, I don't startup a car or drive it until i have a wideband on it to monitor. If you have that... and can keep an on it... you'll probably be fine to drive to the tuner.</TD></TR></TABLE>
Correct. Make sure you have a wideband and I would stay out of boost. Make sure you are running at least 14.7:1 to a 15.9:1 a/f while driving in vacuum. If you get close to 0psi you will want to be around a 13.0:1 a/f.
Other than that, you should be fine.
Re: Am I going to need a re-tune? (PrecisionH23a)
Well I dont have a wideband, jeez this is frustrating, i have been away from my car for 3 weeks now putting these new parts in, its practically a fresh motor now, i mean I could try my best to stay outta boost on my way to the shop which is like a 2 hr drive becuz thats the closest for me.
Same compression and all? Was this just a replace with identical parts refresher? If so... you'll probably be fine and quite close... but I'd still recommend a retune.
everything is just a refresh, i swapped out the original oem pistons with CP forged pistons all the same size i didnt do a bore change or anything... I just want to know if it will all be ok, but yes eventually i will get to the tune shop and have it retuned or if it even needs it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dangerranger21 »</TD></TR><TR><TD CLASS="quote">everything is just a refresh, i swapped out the original oem pistons with CP forged pistons all the same size i didnt do a bore change or anything... I just want to know if it will all be ok, but yes eventually i will get to the tune shop and have it retuned or if it even needs it...</TD></TR></TABLE>
You changed piston design, composition and compression... it will need it. You did rods also right?
