Always come up missing half quart or more of oil where did it go?
On my boosted h22.....its stock and motor is very very strong. Doesnt smoke or anything at WOT.....can to much oil pressure cause it to burn oil? I have a restrictor but hasnt put in yet. I was told the reason we run -3an lines is to restrict it enough, but then other people say to use restrictor and that'll save from burning oil. Just curious if everyone else has to put inline restrictors in or what the case is. My oil pressure at WOT is like 60-70psi...
Re: Always come up missing half quart or more of oil where did it go? (gdrum)
i had this prob on mine over the weekend . i think the oil getting too hot is burning it . i went to 20w50 to hope it helps. my oil was smoking hotttt when i drained it. time for an oil cooler too, lol. it never ends
Re: Always come up missing half quart or more of oil where did it go? (itr206)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr206 »</TD></TR><TR><TD CLASS="quote"> it never ends</TD></TR></TABLE>
Isn't that the truth
Re: Always come up missing half quart or more of oil where did it go? (FOrSfEd)
well should we run inline restrictors? or si -3an line on our hondas enough restriction...?
since you already have the restrictor, use it. It can't hurt....see if it fixes your problem.
Re: Always come up missing half quart or more of oil where did it go? (FwdCivicHatch)
Welcome to the H22 oil burning club. About 99% of all Preludes burn oil, even new. Its just a natural thing for them. My car has no oil leaks, compression is perfect and it still burns oil. I have to add about 1qt every 3000miles.
Re: Always come up missing half quart or more of oil where did it go? (Revi-Ra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revi-Ra »</TD></TR><TR><TD CLASS="quote">Welcome to the H22 oil burning club. About 99% of all Preludes burn oil, even new. Its just a natural thing for them. My car has no oil leaks, compression is perfect and it still burns oil. I have to add about 1qt every 3000miles. </TD></TR></TABLE>
you should be doing a oil change by then....maybe not, I do??
sh!t happens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOrSfEd »</TD></TR><TR><TD CLASS="quote">
Isn't that the truth</TD></TR></TABLE>
i vouch on that one
i vouch on that one
actually most hondas lose about a quart every 3000 miles or soo...stock
Do you have your PCV valve connected?
you might not be burning oil at wide open throttle but under heavy vaccuum.
have someone bump the throttle and stand behind the car when they let off the throttle ,it will go into higher vac..see if it puffs some smoke for a few seconds...
If its burning it under vac..it could be intake valve seals or a PCV valve.
As for using 20-50, i wouldnt use that thick oil in a honda..the thicker oil goes through oil passages slower when you start up and your cams depend on that oil bc they have no bearings..i stick to 10-30w
Modified by D@nnY at 9:45 PM 5/11/2004
Modified by D@nnY at 9:48 PM 5/11/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">i had this prob on mine over the weekend . i think the oil getting too hot is burning it . i went to 20w50 to hope it helps. my oil was smoking hotttt when i drained it. time for an oil cooler too, lol. it never ends</TD></TR></TABLE>
Aren't oil coolers really hard on the oil pump? This is something that I read multiple times on here.
BTW, H22s naturally burn oil. I am normally .5-1 quart low (Mobil non-syn 10w-30) after 2000 miles and I have NO LEAKS, plus I am running N/A with a stock P13. However, I do run a half quart more then what's recommended. And yes I change my oil after 2000 miles, better safe then sorry. I will be changing my oil every 1000 miles when my motor is boosted. The added heat of FI breaks down the oil at a much more rapid pace then N/A. But what do know.
97grnrs
11-21-2006 10:35 AM
