Air/Fuel ratio on turbo b16 6psi
I just bought a 00 civic si that is b00sted.. It has AEM managment and gauge and was told that my air/fuel ratio was high.. I was wondering what it should be at or around?? I am running 6psi if that matters.. I am new to the BOOSTED WORLD. Any info would be great on how to keep up with it.
Re: (JDMlyfestyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">Out of boost just cruising around 14- 14.7 is ideal..
when your under WOT and in boost 12.0-12.5 in the AFR</TD></TR></TABLE>
On a b16 with a c/r of 10.2:1 I would say more like 11.5:1-12.0:1 under full load in boost.
Re: (raresi99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raresi99 »</TD></TR><TR><TD CLASS="quote">Thanks for info... around 11 cruising and the jumps to around 14.5-14.7 under full boost</TD></TR></TABLE>
I think you got that backwards or atleast I hope so
Re: (popnvtec)
Idealistically you should be running between a 12-13:1 AFR at WOT as that is the AFR where your best power will be made. Running a richer AFR cools down combustion VERY slightly and adds a bit more margin of error. Many individuals claim that you should run between 12-13:1 AFR and use your ignition timing to offset any sort of detonation or issues like that.
http://www.innovatemotorsports...s.php
http://www.innovatemotorsports...h.php
http://www.innovatemotorsports...s.php (6 down, by your friend Ben Stader)
Re: (nowtype)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nowtype »</TD></TR><TR><TD CLASS="quote">Idealistically you should be running between a 12-13:1 AFR at WOT as that is the AFR where your best power will be made. Running a richer AFR cools down combustion VERY slightly and adds a bit more margin of error. Many individuals claim that you should run between 12-13:1 AFR and use your ignition timing to offset any sort of detonation or issues like that.
http://www.innovatemotorsports...s.php (6 down, by your friend Ben Stader)</TD></TR></TABLE>
Very nice links never seen them
