air/fuel ratio
What kind of air/fuel ratio do I want for my power band? I'm looking for my answer to be like this: 1-4k = 14.5, 5-6k = 13.0, etc. I have a H22A4. My VTEC is currently set at 5100rpm.
@ sea leavel prob 11.5:1 meby 12.5:1 max but it will differ for each engin. usualy what ever produces the most power with decent egt's (I know, I know). always best to be on the safe side though.
p.s. when u dyno, when your fueling is all done, set ur vtec at 3k, and make a run. then set it at 7800 and make a run. where the tourq courves cross, set ur vtec there.
Re: (grndcont)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grndcont »</TD></TR><TR><TD CLASS="quote">p.s. when u dyno, when your fueling is all done, set ur vtec at 3k, and make a run. then set it at 7800 and make a run. where the tourq courves cross, set ur vtec there.</TD></TR></TABLE>
VTEC at 3k? I thought it was unsafe to get it that low? |
na, it just bogs like hell. besides, youre only doing it for one run to see the curve. if you don't feel comforteble, set it at 4k.
Re: (grndcont)
what a/f you want shouldn't be from what RPM your motor is spinning at but rather load.
Therefore, when i tune, i go for 12.0:1 for anything above 5psi. 12.5:1 from 3psi to 5psi and about 13.5:1 from 0-3psi. Off boost, I'm looking around 13.5-14.5:1 Of course, this depends on your motor, plugs, timing, base timing, compression, etc etc.. |
