Air Flow (lbs. per min.) on SC34, GT32 GT35.
The question is clearly stated. Im looking for a turbo that will flow around 40-50lbs. per min. SC61 i think is 60, and i just dont need one like that. Better than your average T3/T04E, 280-400whp for daily driven car and at 400whp no stress on the turbo (maxing out). thanks.
Re: Air Flow (lazerus)
Well i know that its a 57 trim. And i think the SC61 and GT35 flow around 60lbs per min. I want to know about the GT32 and SC34. Do you think that the GT32 will produce more power than the Sc34. for example.. at 10psi would the GT32 make more. and would its max power be higher? im looking for 400whp. preferably pump gas or close to 400.
Re: Air Flow (1SlowSi)
Isn't is incorrect to compare maximum air flow numbers when you're not running the compressor at maximum rpm? You'd need a pressure ratio a lot higher than ~1.6 to get to max flow.
Or, are compressors so similar with how they flow b/w different wheels that we can linearly assume that if it flows better at max rpm, then then it'll also comparatively flow better at a lower rpm?
Re: Air Flow (IN VTEC)
