AEM's In-Tank 320 LPH Fuel Pump Released
http://i31.photobucket.com/albums/c3...000_header.jpg
Thought I would share information regarding AEM's new High Flow In-Tank Fuel Pump. AEM's results are astonishing with a single in tank pump capable of support 1000hp, of course horse power capability is ultimately dependent on fuel hose diameter, and system electrical voltage and amperage capabilities. We have tested this pump on our 724whp Civic Wagovan with impeccable results. I must say, I am very impressed with this pumps capability! AEM’s High Flow In-Tank Fuel Pump is designed for high performance naturally aspirated and forced induction EFI vehicles. It delivers reliable performance and high volumes of fuel flow for roughly half the cost of comparable performance fuel pumps. The AEM High Flow In-Tank Fuel Pump (PN 50-1000) flows 320 lph (84 gph) at 43 PSI and is capable of supporting over 1,000 HP at 43 PSI.* AEM High Flow In-Tank Fuel Pump Features: - Designed for high output naturally aspirated and forced induction EFI vehicles - In-Tank design - Tested to flow 320 lph @ 43 PSI - 39mm diameter fits most applications - Offset inlet design eases installation - Each pump individually tested - For gasoline vehicles (pump life may be diminished when used with E85 fuel) - Kit includes fuel pump, rubber sleeve and end caps, pre filter, hose, clamps and flying lead http://i31.photobucket.com/albums/c3..._Power_Med.jpg AEM High Flow In-Tank Fuel Pump (PN 50-1000) flow and power graph (in PSI) at average pph, .5 BSFC and .65 BSFC. The data in this graph represents a 10 pump average of results collected in testing at AEM. Every AEM High Flow Fuel Pump is tested for flow, PRV activation, and amperage draw. The horsepower figures in this graph are approximate and will vary based on your vehicle’s set-up. http://i31.photobucket.com/albums/c3...essure_Med.jpg The AEM 50-1000 flows 320 lph at 43 PSI. http://i31.photobucket.com/albums/c3...essure_Med.jpg AEM’s High Flow In-Tank Fuel Pump has a low current draw even at 80 SPI due to its internal turbine pump design. TECHNICAL SPECS: Weight: 10.1oz (285grams) Outside Diameter: 39mm OD External Materials: Black plated steel with laser etching Inlet Fitting: 7.7mm ID, 11.0mm OD Outlet Fitting: 8 mm hose clamp PRV Activation: 90 PSI Impeller Design: Single Scroll Hard Anodized Aluminum Turbine VOLTAGE SPECS: Connector Terminal: 6 mm Spade (pos/neg) Min Voltage Input: 6 volts Max Voltage Input: 18 volts Current Draw (40 psi): 12 amps (13.5v) Current Draw (80 psi): 15 amps (13.5v) * Power rating given at 43 PSI, 13.5v at the pump with a BSFC of .5. Flow capability for horsepower support is ultimately dependent on fuel hose diameter, and system electrical voltage and amperage capabilities. http://i31.photobucket.com/albums/c3...rawing_Med.jpg |
Re: AEM's In-Tank 320 LPH Fuel Pump Released
No Price + No E85 = No Good
Looks like a knock off of the Aeromotive pump... |
Originally Posted by N3va3vaSatisfi3d
(Post 47950664)
Originally Posted by Julio@Bisimoto
(Post 47950741)
Price is on our website if you want to see for yourself and not everyone is running E85. ;)
Just a thought.. |
$110 not bad. The only problem is for guys like me running e85. I'm about to max out my dual Walbro 255's and was looking to upgrade
The other factor is being that E10 is more prevelant than you might realize. This coupled with the fact that it may vary well increase in the future... ;)
I dont believe a single thing/spec that comes out of bisi's shop.
Originally Posted by highroller54
(Post 47951057)
The pump is compatible with E85 however the life of the pump may decrease due to the lubricating properties of E85 vs gasoline.
Originally Posted by Rtype16
(Post 48001440)
Im not sure but I do know that I have seen many failures of the regular 400.
Originally Posted by kbouchard1092
(Post 48005489)
While this topic is up since id like to be making the switch to E85 soon. What makes the Walbro 450(E85 ) more compatible for E85. What parts are changed and how does it differ from The walbro 400.
Post #5. It looks like they sealed the wires, so possibly e85 was eating out the wires making them to fail? I plan on trying out one of the "E85" capable walbro 400s next year. |
Originally Posted by LightningTeg
(Post 48005699)
Yea i saw that the wires were changed. However the other response was it failed due to lubrication issues...That is contradicting to just a wire/sealing change. You would think there were other changes if that was indeed the root cause of the failure (lubrication issues.)
| All times are GMT -8. The time now is 08:24 PM. |
