aem fuel rail and gas leaking
gas is leaking out where the banjo bolt is. i put all the washers in and everything and i dont know why its still leaking, but is there a way to stop the leaking? its where the fuel inlet is.
Re: aem fuel rail and gas leaking (eMpAtHy)
you sure you have it together right and have it really tightened down? did you put teflon tape on the threads?
I had the same problem when I first installed mine a few years ago. I ended up having to sand the anodizing smooth with 400 grit sand paper, then it finally sealed.
Re: aem fuel rail and gas leaking (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 »</TD></TR><TR><TD CLASS="quote">you sure you have it together right and have it really tightened down? did you put teflon tape on the threads?</TD></TR></TABLE>
You never want to put teflon tape on banjo bolt threads. Banjo bolts seal using washers, not the threads.
Re: aem fuel rail and gas leaking (Boondock Saint)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boondock Saint »</TD></TR><TR><TD CLASS="quote">
You never want to put teflon tape on banjo bolt threads. Banjo bolts seal using washers, not the threads.</TD></TR></TABLE>
Never hurt my car and it never leaked
i tightened it, not to my full strength. afraid i might screw up the threads. can i tighten the top nut really tight? because if i can, ill just go ahead and do it.
