AEM EMS + DSM 450cc injectors
I already have DSMs, you ****. I'm running the VAFC hack right now and it's not giving me the best of days. I was already planning on getting 720s in a couple of weeks. Calm down.
Re: AEM EMS + DSM 450cc injectors (liam821)
Hey liam thanks for your time helping me out. But apparently the problems are still there. I suspect my o2s could be fouled but I was eventually going to get the EMS anyway.
Re: AEM EMS + DSM 450cc injectors (DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 »</TD></TR><TR><TD CLASS="quote">Hey liam thanks for your time helping me out. But apparently the problems are still there. I suspect my o2s could be fouled but I was eventually going to get the EMS anyway. </TD></TR></TABLE>
Using the dsm injectors shouldnt be a problem. If i recall you can set the EMS to use high or low impedince injectors.
As far as the O2 goes...try putting a volt meter to the o2 sensor and make sure its working normally. It shold cycle between 0-1volts.
liam
liam
it sucks now actually but that's because my injectors are probably dirty (i bought them used) and not flowing what they suppose to be. Planning to go with some bigger ones soon.
Actually, the EMS is set up to run high impedance injectors. I f you want to run low impedance, then you need to install a resistor block. You also need to make you that the battery offset table is set correctly. There are wizards in the newest firmware versions (v1.03) for this purpose.
rice a roni
05-20-2006 02:32 AM
threatcon13
01-31-2002 08:32 AM
