Adjustable Fpr???
would should i run w/ my DRAG III kit @ 10psi??? b&m, aem, areomotive??? what do you use??? do i even need one?
thanks |
Re: Adjustable Fpr??? (SpeedRacer00-667)
You may need to run a fpr to lean out the idle mixture after installing the new pump.I have a aem and it works ok.The b&m won't do you to much good it's really only effective to raise the boost.You will need to run a boost dependent fpr along with the turbo (I'm not sure what all comes in the kit).
Re: Adjustable Fpr??? (5gen-hybrid)
i need some help........what should i use???
do u have an afc? If u do, u don't need a fpr.
i use a aem,holly 255lph pump,and a fmu.
