Adding a heater core to turbo coolant lines: Discuss the pros/cons
#27
Re: Adding a heater core to turbo coolant lines.
If you got a SPAL fan that was equivalent in diameter to what you have now, you're saying it wouldnt clear?
Woefully inadequate? I wouldnt go that far. lol. How many single cams do you know of that make good power that have been operational for over a decade? Thats gotta say something. I know the cooling aspect of the setup needs work and thats why I asked. This setup only heats up if I get on it HARD.
Thanks.
Thanks.
#28
Re: Adding a heater core to turbo coolant lines: Discuss the pros/cons
My apologies! The SPAL will fit! Its the Flex A Lite shrouded ran fan that will not clear my wastegate. My bad. I will order one soon but in the meantime I think I will try the idea I had. See what happens. Thanks
#30
The problem as i see it that with a closed loop there you dont have a presure relief mechanism like we have with the normal car rad.
Youll have to chech if the mini rad will endure pressure elevation due to deperature.Longer expansion happy hoses will help the situation.
#32
#33
Ahhh ok. though it was about a second closed loop with a water pump.
#34
OP, I would think that your idea of using a heater core can help with cooling, but I'm not so sure by how much.
The main factor you will need to consider is how you are going to get air to flow through it.
Ducting from a fog light opening to the core opening and then to a low pressure area would assure airflow goes through the core.
I would really look into ducting for the radiator, I know you tried and it didn't work out but you might just need to spend more time getting creative assuring that you can get as much of a pressure differential between the front and back of your radiator.
Even if the shroud needed to be built around the intake I think it would be possible.
An air dam under the bumper cover will help too, the lower you can make it the better. The science here is simply blocking air from going under the car which lowers air pressure under the engine bay, lower pressure in the engine bay will improve airflow across your radiator and intercooler since they are seeing high pressure from the bumper cover opening.
#35
B18EG6
03-22-2003 05:31 PM
