ACURA PROCHARGER KIT NEED INFO...
ANYBODY RUNNING A PROCHARGER KIT..IS IT GOOD OR NOT..ANY DYNO NUMBERS...AND HOW MUCH PSI ARE YOU RUNNING......AND YOUR ENGINE SPEC....
IT S ALREADY ORDER..
PLANNING TO RUN B18C ENGINE AT 14PSI..
LINK TO THE PROCHARGER KIT...http://www.procharger.com/SPOR...shtml
THKS A LOT FOR YOUR HELP
Re: (civic_sc)
It's a kit that produces basically zero low end gain, and gains on the top end that arn't as good as a turbo. You have to deal with belt slip and changing pullies, and they just arn't as good of a power adder as a turbo kit, but at a significantly higher cost. Nobody on here runs one because they arn't very good.
96blkteggy
03-19-2011 07:17 AM
