About To Boost My LS, Help Me Out!
I'm about to go Turbo really, really soon. I just kinda wanted to know what 1/4 times I'll be getting, and what kinda power numbers I'll be putting to the wheels with a DRAG III kit on my LS. (5speed) Stock internals. The most common numbers I think is like high 12s to low 13s. As far as power to the wheels I've seen 230-245whp and about 210 LBS Torque. How many lbs should I run? I want this to be as reliable as possible. 7-9 LBS daily?
Drag III Kit
In Tank Fuel Pump
S-AFC
3" Apexi N1 Exhaust
310cc Injectors
Anything I'm missing? Let me know!
[Modified by QUICKTEG, 2:30 PM 4/8/2003]
Drag III Kit
In Tank Fuel Pump
S-AFC
3" Apexi N1 Exhaust
310cc Injectors
Re: About To Boost My LS, Help Me Out! (QUICKTEG)
What's the specs on the turbo....and if you want to crank up the boost without worrying about lean conditions maybe you should think about getting at least the 440cc or 550cc. and getting some sort of fuel management system....EMS, Hondata, Power FC....or your APEXi SAFC will do....I'm trying out the E-manage and Profec E-01 route...i'm picking up my USB Type A to B cable.....that could be another route....keep the intank, but what LPH is it? With proper tuning I've seen just a wide range of numbers, but you'll hit the ceiling fast with the 310cc's....TUNING IS KEY! CORRECT A/F AND TIMING...
[Modified by mamaboy, 9:37 PM 4/8/2003]
Re: About To Boost My LS, Help Me Out! (InTeGrA B18b1)
my friend pulled a 12.40 at 109mph with a bone stock ls, 12-1 fmu stock computer, no fuel management what so ever. oh and 310cc rc injectors. Thats it
i think it was 12-13 psi of bost drag 3 kit t3t4 63 trim turbo, on slicks, in a 95 civic coupe dx
Re: About To Boost My LS, Help Me Out! (hybridb18)
did he upgrade his fuel pump?? either way, wouldnt you run really high fuel pressures with that setup?
So I should get 450cc injectors instead of 310? I don't wanna boost high. If i could break 12s i'll be happy.
yea he had a fuel pump 255lph i think. And no, the motor never blew, that motor was boosted on for about 2 years like that. it dynoed 264hp and 226 tq
i'm still low low 14's and i'm at 10 psi of boost
maybe it's just me
or my stock exhaust/ clutch
Re: About To Boost My LS, Help Me Out! (TurbothisLS)
not as easy as you think
maybe it's just me
maybe it's just me
Re: About To Boost My LS, Help Me Out! (Arturbo)
ran 13.2 in my teg with a drag kit at 8lbs. I tried the SAFC hack with the DSM injectors..... I wouldn't waste your time. Especially if you are going to tune yourself. Go standalone and get the piece of mind that comes with it. You will be happier and it will actually cost less in the long run.
im goin turbo soon as well?
what else is recommended to change?
for example
oil pan gasket, can seal, etc.
thanks
for example
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo »</TD></TR><TR><TD CLASS="quote"><BLOCKQUOTE>quote:<HR>So I should get 450cc injectors instead of 310? I don't wanna boost high. If i could break 12s i'll be happy.
maybe it's just me
or my stock exhaust/ clutch<HR></BLOCKQUOTE>
Its your exhaust..</TD></TR></TABLE>
No i'm going to have to say it's the driver. 220 hp and 210ft lbs of tq should get a better time then 14's
maybe it's just me
HT Username
15
03-09-2005 05:15 PM
Chip398193
11-19-2001 10:55 AM
